hello, i have a problem in that the 'alert' text (where the game flashes a message to you, like 'thieves attack!' keeps flashing forever until a restart. is there a fix for this? unmodded steam SE version install.
Hello sebmojo
where are you currently in the game, please send us your current saved game,
You can find it under: C:\Users\ -Your Account- \Documents\My Games\Enderal Special Edition\Saves
A save always consists of to same named files, an ess file and a skse file. You can pack the files into an archive (example: zip, 7z..., skse is not accepted by forum) and then upload this here using the extended reply option under "File attachments".
Did you use any cheats?
PS.
I hope you have created many different manual savegames, because loading a older save solves the most problems by itself^
(so if possible, don't just rely on auto- or quicksave)
PS.
09.07.2024 10:59Stefanie wrote: Hello sebmojo
PS.
flashing alert text Saves.7z
(1.49 MiB) Downloaded 549 times
and no, no cheats, no mods. the flashing text persists through zone changes, sleeping, meditation, basically everything but a full restart.
i just double checked, and saving manually then reloading the save still has the text persisting - needs a full restart of the game.
but if another text happens then it will take precedence. also, quitting to the main menu doesn't help - it needs to be quit to desktop.
Where does this message appear, in the center of the image or perhaps at the top left?
Can you please take a screenshot of the message?
Do you have any background programs or graphics tools that might be showing something?
We do not have this message and therefore cannot clearly reproduce your error.
Otherwise, try repairing the installation via Steam
if that doesn't work, do a clean reinstall (a bit more effort):
- Uninstall Enderal
- Manual delete the folder with possible game remnants under: ...\Steam\SteamApps\common\Enderal Special Edition
- Delete the settings by emptying the folder: C:\Users\-Your Account-\Documents\My Games\Enderal Special Edition
!with the exception of the "Saves" folder contained there, in which the game saves are located!
- Delete the contents of: C:\Users\-Your Account-\AppData\Local\Enderal Special Edition
- Restart and then install Enderal again
