Hello everyone.
Yesterday I bought Skyrim Special Edition from Steam just to be able to play Enderal.
I installed from Steam Enderal Special Edition and after the launcher, on the home screen, when I click on new game for a moment it seems that it will start, but immediately I get the following message and returns me to the home screen:
"EnderalSE.dll is not loaded! The game will not run properly. Verify integrity of your files.
This may also happen, if your version of SKSE or Enderal is too old. In this case, it is advised to upgrade".
My computer more than meets all the minimum requirements.
Things I've tried that didn't fix it:
Verify file integrity.
Run as administrator.
Reinstall Endereal and Steam.
Install Skyrim.
Modify the settings in a thousand ways.
Can anyone help me? thank you very much!
Install Skyrim.
Hello gomiton!
Possible solutions:
1. your anti-virus program may be causing problems here (e.g. Windows defender or another program you are using). Put the Enderal SE folder there on the white list.
2. disable the write protection that Windows may have set on the game folder (right-click on folder -> Properties -> uncheck "read-only")
3. if this does not help please send us your launcher.log here as an attachment (...\Steam\SteamApps\common\Enderal Special Edition\EnderalLauncher\system\log)
Skyrim SE does not need to be installed to play Enderal SE. They are separate games with their own folders.
Possible solutions:
Unfortunately neither the antivirus nor the folder protection worked.
I also moved the game to another drive with no results.
My operating system is Windows 10 recently upgraded.
Here is the launcher.log:
Code Select all
[[ Starting Launcher ]]
Log started at 2023/12/24 10:59:33
Release ID: A65
Release version: Steam
Build date: 24/12/2023 9:48:50
Creation date: 24/12/2023 9:48:50
App start location: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\
App game folder: Enderal Special Edition\
Operating System: Microsoft Windows NT 6.2.9200.0
NET Versions:
Language: ES
Build version: (Steam)
Game version: (Steam)
Internet connection: True
Installation status: False
Steam status: True
OneTweak status: True
ENBoost status: True
Directory search status: True
Master found: True
SKSE found: False
Last external startup path: 0
Last external executable: 0
> Start logging:
<10:59:33> Conf - Initialize conf file
<10:59:33> Conf - Unpack Readme
<10:59:33> Conf - Initialize conf file [DONE]
<10:59:33> Conf - Save conf file
<10:59:33> Conf - Save conf file [DONE]
<10:59:33> Conf - Checking Environment
<10:59:33> Conf - Checking Environment [DONE]
<10:59:33> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\system\ recursive
<10:59:33> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\update\ recursive
<10:59:33> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\backup\ top level
<10:59:33> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\ top level
<10:59:33> Main - Initialize Unpatcher
<10:59:33> Main - Unpatcher [DONE]
<10:59:33> Main - Create environment
<10:59:34> Main - Create environment [DONE]
<10:59:34> Main - REG ENTRY
<10:59:34> Main - Initialize network
<10:59:34> Net - Connection enabled in settings
<10:59:34> Net - System is connected to network
<10:59:34> Net - Try to establish server connection thread
<10:59:34> Net - Thread STARTED
<10:59:34> Main - Initialize network [DONE]
<10:59:34> Main - Initialize intervall
<10:59:34> Net - Connect to [DL4]
<10:59:34> Main - Initialize PanBase
<10:59:34> Main - Initialize PanBase [DONE]
<10:59:34> Main - Initialize CPanel
<10:59:34> Cp - Cp Initialisation
<10:59:34> Main - Initialize CPanel [DONE]
<10:59:34> Cp - Try download Cp file
<10:59:34> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\system\config\ top level
<10:59:34> Conf - Hardware Scan:
<10:59:34> Conf - CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz, Speed: 1190, Cores: 8
<10:59:34> Conf - GPU: Intel(R) UHD Graphics, Memory: 1 GB
<10:59:34> Conf - RAM: 15 GB
<10:59:34> Conf - DISC: 104329 MB
<10:59:34> Cp - Downloaded Cp file
<10:59:34> Cp - Check Cp file
<10:59:34> Cp - Abort: Cp file to short
<10:59:37> Settings - <LOAD> Parsing fSplitDistanceMult done [1,5]
<11:00:04> Settings - Settings saved EnderalPrefs
<11:00:04> Settings - <LOAD> Parsing fSplitDistanceMult done [1,5]
<11:00:08> Conf - Save conf file
<11:00:08> Conf - Save conf file [DONE]
<11:00:08> Exit(A)
Log started at 2023/12/24 11:00:18
Release ID: A65
NET Versions:
Language: ES
Steam status: True
Master found: True
SKSE found: False
> Start logging:
<11:00:18> Conf - Initialize conf file
<11:00:18> Conf - Unpack Readme
<11:00:18> Conf - Initialize conf file [DONE]
<11:00:18> Conf - Save conf file
<11:00:18> Conf - Save conf file [DONE]
<11:00:18> Conf - Checking Environment
<11:00:18> Conf - Checking Environment [DONE]
<11:00:18> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\system\ recursive
<11:00:18> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\update\ recursive
<11:00:18> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\backup\ top level
<11:00:18> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\ top level
<11:00:18> Main - Initialize Unpatcher
<11:00:18> Main - Unpatcher [DONE]
<11:00:18> Main - Create environment
<11:00:18> Main - Create environment [DONE]
<11:00:18> Main - REG ENTRY
<11:00:18> Main - Initialize network
<11:00:18> Net - Connection enabled in settings
<11:00:18> Net - System is connected to network
<11:00:18> Net - Try to establish server connection thread
<11:00:18> Net - Thread STARTED
<11:00:18> Main - Initialize network [DONE]
<11:00:18> Main - Initialize intervall
<11:00:18> Net - Choose server
<11:00:18> Net - Connect to [DL1]
<11:00:18> Net - Server connection attempt #1
<11:00:18> Main - Initialize PanBase [DONE]
<11:00:18> Main - Initialize CPanel
<11:00:18> Cp - Cp Initialisation
<11:00:18> Main - Initialize CPanel [DONE]
<11:00:18> Cp - Try to compare server with local file
<11:00:18> Conf - Hardware Scan:
<11:00:18> Conf - CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz, Speed: 1190, Cores: 8
<11:00:18> Conf - GPU: Intel(R) UHD Graphics, Memory: 1 GB
<11:00:18> Conf - RAM: 15 GB
<11:00:18> Conf - DISC: 104328 MB
<11:00:18> Cp - Connection port: 80
<11:00:18> Cp - Connection default port: True
<11:00:18> Cp - Connection proxy bypassed: True
<11:00:19> Cp - Connection OK
<11:00:19> Cp - No content delivered: Exception occurred!
Exception type: System.ArgumentNullException
Exeption name : ArgumentNullException
Message : El valor no puede ser nulo.
Nombre del parámetro: String
Source : mscorlib
Funtion : Void StringToNumber(System.String, System.Globalization.NumberStyles, NumberBuffer ByRef, System.Globalization.NumberFormatInfo, Boolean)
Result : -2147467261
Data : System.Collections.ListDictionaryInternal
Stacktrace:
en System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
en System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
en System.Int32.Parse(String s)
en Launcher_01.formPanCPanel.checkCPFile()
<11:00:19> Cp - Check Cp file
<11:00:19> Cp - Abort: Cp file to short
<11:00:23> Conf - Save conf file
<11:00:23> Conf - Save conf file [DONE]
<11:00:23> Exit(A)
Log started at 2023/12/24 11:09:36
Release ID: A65
Build date: 24/12/2023 11:03:42
NET Versions:
Language: EN
Steam status: True
Master found: True
SKSE found: False
> Start logging:
<11:09:36> Conf - Initialize conf file
<11:09:36> Conf - Unpack Readme
<11:09:36> Conf - Initialize conf file [DONE]
<11:09:36> Conf - Save conf file
<11:09:36> Conf - Save conf file [DONE]
<11:09:36> Conf - Checking Environment
<11:09:36> Conf - Checking Environment [DONE]
<11:09:36> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\system\ recursive
<11:09:36> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\update\ recursive
<11:09:36> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\backup\ top level
<11:09:36> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\ top level
<11:09:36> Main - Initialize Unpatcher
<11:09:36> Main - Unpatcher [DONE]
<11:09:36> Main - Create environment
<11:09:36> Main - Create environment [DONE]
<11:09:36> Main - REG ENTRY
<11:09:36> Main - Initialize network
<11:09:36> Net - Connection enabled in settings
<11:09:36> Net - System is connected to network
<11:09:36> Net - Try to establish server connection thread
<11:09:36> Net - Thread STARTED
<11:09:36> Main - Initialize network [DONE]
<11:09:36> Main - Initialize intervall
<11:09:36> Net - Connect to [DL2]
<11:09:36> Main - Initialize PanBase
<11:09:36> Main - Initialize PanBase [DONE]
<11:09:36> Main - Initialize CPanel
<11:09:36> Cp - Cp Initialisation
<11:09:36> Main - Initialize CPanel [DONE]
<11:09:36> Cp - Try to compare server with local file
<11:09:36> Conf - Hardware Scan:
<11:09:36> Conf - CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz, Speed: 1190, Cores: 8
<11:09:36> Conf - GPU: Intel(R) UHD Graphics, Memory: 1 GB
<11:09:36> Conf - RAM: 15 GB
<11:09:36> Conf - DISC: 104627 MB
<11:09:36> Cp - Connection port: 80
<11:09:36> Cp - Connection default port: True
<11:09:36> Cp - Connection proxy bypassed: True
<11:09:37> Cp - Connection OK
<11:09:37> Cp - 22/12/2020 13:58:21 24/12/2023 10:59:34
<11:09:37> Cp - Up-to-date
<11:09:37> Cp - Check Cp file
<11:09:37> Cp - Abort: Cp file to short
<11:09:38> Settings - <LOAD> Parsing fSplitDistanceMult done [1,5]
<11:09:47> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\data\SKSE\Plugins\ top level
<11:10:00> Settings - Settings saved EnderalPrefs
<11:10:00> Settings - <LOAD> Parsing fSplitDistanceMult done [0,4]
<11:10:05> Conf - Save conf file
<11:10:05> Conf - Save conf file [DONE]
<11:10:05> Exit(A)
Log started at 2023/12/24 11:10:35
Release ID: A65
NET Versions:
Language: EN
Steam status: True
OneTweak status: False
Master found: True
SKSE found: False
> Start logging:
<11:10:35> Conf - Initialize conf file
<11:10:35> Conf - Unpack Readme
<11:10:35> Conf - Initialize conf file [DONE]
<11:10:35> Conf - Save conf file
<11:10:35> Conf - Save conf file [DONE]
<11:10:35> Conf - Checking Environment
<11:10:35> Conf - Checking Environment [DONE]
<11:10:35> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\system\ recursive
<11:10:35> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\update\ recursive
<11:10:35> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\backup\ top level
<11:10:35> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\ top level
<11:10:35> Main - Initialize Unpatcher
<11:10:35> Main - Unpatcher [DONE]
<11:10:35> Main - Create environment
<11:10:35> Main - Create environment [DONE]
<11:10:35> Main - REG ENTRY
<11:10:35> Main - Initialize network
<11:10:35> Net - Connection enabled in settings
<11:10:35> Net - System is connected to network
<11:10:35> Net - Try to establish server connection thread
<11:10:35> Net - Thread STARTED
<11:10:35> Main - Initialize network [DONE]
<11:10:35> Net - Connect to [DL4]
<11:10:35> Net - Server connection attempt #1
<11:10:35> Main - Initialize PanBase
<11:10:35> Main - Initialize PanBase [DONE]
<11:10:35> Main - Initialize CPanel
<11:10:35> Cp - Cp Initialisation
<11:10:35> Main - Initialize CPanel [DONE]
<11:10:35> Cp - Try to compare server with local file
<11:10:35> Conf - Hardware Scan:
<11:10:35> Conf - CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz, Speed: 1190, Cores: 8
<11:10:35> Conf - GPU: Intel(R) UHD Graphics, Memory: 1 GB
<11:10:35> Conf - RAM: 15 GB
<11:10:35> Conf - DISC: 104627 MB
<11:10:35> Cp - Connection port: 80
<11:10:35> Cp - Connection default port: True
<11:10:35> Cp - Connection proxy bypassed: True
<11:10:35> Cp - Connection OK
<11:10:35> Cp - 22/12/2020 13:58:21 24/12/2023 10:59:34
<11:10:35> Cp - Up-to-date
<11:10:35> Cp - Check Cp file
<11:10:35> Cp - Abort: Cp file to short
<11:10:37> Settings - <LOAD> Parsing fSplitDistanceMult done [0,4]
<11:10:55> Settings - Settings saved EnderalPrefs
<11:10:55> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<11:11:08> Data - Datafiles saved
<11:11:13> Data - Datafiles saved
<11:11:20> Data - Datafiles saved
<11:11:27> Conf - Save conf file
<11:11:27> Conf - Save conf file [DONE]
<11:11:27> Exit(A)
Log started at 2023/12/24 12:04:16
Release ID: A65
NET Versions:
Language: EN
Steam status: True
Master found: True
SKSE found: False
> Start logging:
<12:04:16> Conf - Initialize conf file
<12:04:16> Conf - Unpack Readme
<12:04:16> Conf - Initialize conf file [DONE]
<12:04:16> Conf - Save conf file
<12:04:16> Conf - Save conf file [DONE]
<12:04:16> Conf - Checking Environment
<12:04:16> Conf - Checking Environment [DONE]
<12:04:16> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\system\ recursive
<12:04:16> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\update\ recursive
<12:04:16> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\backup\ top level
<12:04:16> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\ top level
<12:04:16> Main - Initialize Unpatcher
<12:04:16> Main - Unpatcher [DONE]
<12:04:16> Main - Create environment
<12:04:16> Main - Create environment [DONE]
<12:04:16> Main - REG ENTRY
<12:04:16> Main - Initialize network
<12:04:16> Net - Connection enabled in settings
<12:04:16> Net - System is connected to network
<12:04:16> Net - Try to establish server connection thread
<12:04:16> Net - Thread STARTED
<12:04:16> Main - Initialize network [DONE]
<12:04:16> Net - Choose server
<12:04:16> Net - Connect to [DL4]
<12:04:16> Main - Initialize PanBase
<12:04:16> Main - Initialize PanBase [DONE]
<12:04:16> Main - Initialize CPanel
<12:04:16> Cp - Cp Initialisation
<12:04:16> Main - Initialize CPanel [DONE]
<12:04:16> Cp - Try to compare server with local file
<12:04:16> Cp - Connection port: 80
<12:04:16> Cp - Connection default port: True
<12:04:16> Cp - Connection proxy bypassed: True
<12:04:16> Conf - Hardware Scan:
<12:04:16> Conf - CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz, Speed: 1190, Cores: 8
<12:04:16> Conf - GPU: Intel(R) UHD Graphics, Memory: 1 GB
<12:04:16> Conf - RAM: 15 GB
<12:04:16> Conf - DISC: 87111 MB
<12:04:16> Cp - Connection OK
<12:04:16> Cp - 22/12/2020 13:58:21 24/12/2023 10:59:34
<12:04:16> Cp - Up-to-date
<12:04:16> Cp - Check Cp file
<12:04:16> Cp - Abort: Cp file to short
<12:04:20> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<12:04:28> Settings - Settings saved EnderalPrefs
<12:04:28> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<12:04:31> Conf - Save conf file
<12:04:31> Conf - Save conf file [DONE]
<12:04:31> Exit(A)
Log started at 2023/12/24 12:05:44
Release ID: A65
NET Versions:
Language: EN
Steam status: True
Master found: True
SKSE found: False
> Start logging:
<12:05:44> Conf - Initialize conf file
<12:05:44> Conf - Unpack Readme
<12:05:44> Conf - Initialize conf file [DONE]
<12:05:44> Conf - Save conf file
<12:05:44> Conf - Save conf file [DONE]
<12:05:44> Conf - Checking Environment
<12:05:44> Conf - Checking Environment [DONE]
<12:05:44> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\system\ recursive
<12:05:44> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\update\ recursive
<12:05:44> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\backup\ top level
<12:05:44> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\ top level
<12:05:44> Main - Initialize Unpatcher
<12:05:44> Main - Unpatcher [DONE]
<12:05:44> Main - Create environment
<12:05:44> Main - Create environment [DONE]
<12:05:44> Main - REG ENTRY
<12:05:44> Main - Initialize network
<12:05:44> Net - Connection enabled in settings
<12:05:44> Net - System is connected to network
<12:05:44> Net - Try to establish server connection thread
<12:05:44> Net - Thread STARTED
<12:05:44> Main - Initialize network [DONE]
<12:05:44> Net - Choose server
<12:05:44> Net - Connect to [DL6]
<12:05:44> Main - Initialize PanBase
<12:05:44> Main - Initialize PanBase [DONE]
<12:05:44> Main - Initialize CPanel
<12:05:44> Cp - Cp Initialisation
<12:05:44> Main - Initialize CPanel [DONE]
<12:05:44> Cp - Try to compare server with local file
<12:05:44> Conf - Hardware Scan:
<12:05:44> Conf - CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz, Speed: 1190, Cores: 8
<12:05:44> Conf - GPU: Intel(R) UHD Graphics, Memory: 1 GB
<12:05:44> Conf - RAM: 15 GB
<12:05:44> Cp - Connection port: 80
<12:05:44> Cp - Connection default port: True
<12:05:44> Cp - Connection proxy bypassed: True
<12:05:44> Cp - Connection OK
<12:05:44> Cp - 22/12/2020 13:58:21 24/12/2023 10:59:34
<12:05:44> Cp - Up-to-date
<12:05:44> Cp - Check Cp file
<12:05:44> Cp - Abort: Cp file to short
<12:05:50> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<12:06:33> Settings - Settings saved EnderalPrefs
<12:06:33> Settings - <LOAD> Parsing fSplitDistanceMult done [1,1]
<12:11:41> Conf - Save conf file
<12:11:41> Conf - Save conf file [DONE]
<12:11:41> Exit(A)
Log started at 2023/12/24 12:45:08
Release ID: A65
NET Versions:
Language: EN
Steam status: False
Master found: True
SKSE found: False
> Start logging:
<12:45:08> Conf - Initialize conf file
<12:45:08> Conf - Unpack Readme
<12:45:08> Conf - Initialize conf file [DONE]
<12:45:08> Conf - Save conf file
<12:45:08> Conf - Save conf file [DONE]
<12:45:08> Conf - Checking Environment
<12:45:08> Conf - Checking Environment [DONE]
<12:45:08> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\system\ recursive
<12:45:08> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\update\ recursive
<12:45:08> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\backup\ top level
<12:45:08> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\ top level
<12:45:08> Main - Initialize Unpatcher
<12:45:08> Main - Unpatcher [DONE]
<12:45:08> Main - Create environment
<12:45:08> Main - Create environment [DONE]
<12:45:08> Main - REG ENTRY
<12:45:08> Main - Initialize network
<12:45:08> Net - Connection enabled in settings
<12:45:08> Net - System is connected to network
<12:45:08> Net - Try to establish server connection thread
<12:45:08> Net - Thread STARTED
<12:45:08> Main - Initialize network [DONE]
<12:45:08> Net - Choose server
<12:45:08> Net - Connect to [DL4]
<12:45:08> Main - Initialize PanBase
<12:45:08> Main - Initialize PanBase [DONE]
<12:45:08> Main - Initialize CPanel
<12:45:08> Cp - Cp Initialisation
<12:45:08> Main - Initialize CPanel [DONE]
<12:45:08> Cp - Try to compare server with local file
<12:45:08> Conf - Hardware Scan:
<12:45:08> Conf - CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz, Speed: 1190, Cores: 8
<12:45:08> Conf - GPU: Intel(R) UHD Graphics, Memory: 1 GB
<12:45:08> Conf - RAM: 15 GB
<12:45:08> Conf - DISC: 87089 MB
<12:45:08> Cp - Connection port: 80
<12:45:08> Cp - Connection default port: True
<12:45:08> Cp - Connection proxy bypassed: True
<12:45:08> Cp - Connection OK
<12:45:08> Cp - 22/12/2020 13:58:21 24/12/2023 10:59:34
<12:45:08> Cp - Up-to-date
<12:45:08> Cp - Check Cp file
<12:45:08> Cp - Abort: Cp file to short
<12:45:42> Conf - Save conf file
<12:45:42> Conf - Save conf file [DONE]
<12:45:42> Exit(A)
Log started at 2023/12/24 13:54:00
Release ID: A65
NET Versions:
Language: EN
Steam status: False
Master found: True
SKSE found: False
> Start logging:
<13:54:00> Conf - Initialize conf file
<13:54:00> Conf - Unpack Readme
<13:54:00> Conf - Initialize conf file [DONE]
<13:54:00> Conf - Save conf file
<13:54:00> Conf - Save conf file [DONE]
<13:54:00> Conf - Checking Environment
<13:54:00> Conf - Checking Environment [DONE]
<13:54:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\system\ recursive
<13:54:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\update\ recursive
<13:54:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\EnderalLauncher\backup\ top level
<13:54:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\ top level
<13:54:00> Main - Initialize Unpatcher
<13:54:00> Main - Unpatcher [DONE]
<13:54:00> Main - Create environment
<13:54:00> Main - Create environment [DONE]
<13:54:00> Main - REG ENTRY
<13:54:00> Main - Initialize network
<13:54:00> Net - Connection enabled in settings
<13:54:00> Net - System is connected to network
<13:54:00> Net - Try to establish server connection thread
<13:54:00> Net - Thread STARTED
<13:54:00> Main - Initialize network [DONE]
<13:54:00> Main - Initialize intervall
<13:54:00> Net - Server connection attempt #1
<13:54:00> Main - Initialize PanBase
<13:54:00> Main - Initialize PanBase [DONE]
<13:54:00> Main - Initialize CPanel
<13:54:00> Cp - Cp Initialisation
<13:54:00> Main - Initialize CPanel [DONE]
<13:54:00> Cp - Try to compare server with local file
<13:54:00> Conf - Hardware Scan:
<13:54:00> Conf - CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz, Speed: 1190, Cores: 8
<13:54:00> Conf - GPU: Intel(R) UHD Graphics, Memory: 1 GB
<13:54:00> Conf - RAM: 15 GB
<13:54:00> Cp - Connection proxy bypassed: True
<13:54:00> Cp - Connection OK
<13:54:00> Cp - 22/12/2020 13:58:21 24/12/2023 10:59:34
<13:54:00> Cp - Up-to-date
<13:54:00> Cp - Check Cp file
<13:54:00> Cp - Abort: Cp file to short
<13:54:01> Settings - <LOAD> Parsing fSplitDistanceMult done [1,1]
<13:54:55> Settings - <LOAD> Parsing fSplitDistanceMult done [1,1]
<13:55:05> Settings - Settings saved EnderalPrefs
<13:55:05> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<13:55:54> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<14:00:39> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<14:01:57> Settings - Open Launcher log
<14:02:54> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<14:03:15> Settings - Settings saved EnderalPrefs
<14:03:15> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<14:03:16> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<14:05:50> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal Special Edition\data\SKSE\Plugins\ top level
<14:05:55> Settings - Settings saved EnderalPrefs
<14:05:55> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<14:06:08> Conf - Save conf file
<14:06:08> Conf - Save conf file [DONE]
<14:06:08> Exit(A)
Log started at 2023/12/24 14:40:32
Release ID: A65
Creation date: 24/12/2023 14:37:17
App start location: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\
NET Versions:
Language: EN
Steam status: True
Master found: True
SKSE found: False
> Start logging:
<14:40:32> Conf - Initialize conf file
<14:40:32> Conf - Unpack Readme
<14:40:32> Conf - Initialize conf file [DONE]
<14:40:32> Conf - Save conf file
<14:40:32> Conf - Save conf file [DONE]
<14:40:32> Conf - Checking Environment
<14:40:32> Conf - Checking Environment [DONE]
<14:40:32> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\EnderalLauncher\system\ recursive
<14:40:32> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\EnderalLauncher\update\ recursive
<14:40:32> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\EnderalLauncher\backup\ top level
<14:40:32> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\ top level
<14:40:32> Main - Initialize Unpatcher
<14:40:32> Main - Unpatcher [DONE]
<14:40:32> Main - Create environment
<14:40:33> Main - Create environment [DONE]
<14:40:33> Main - REG ENTRY
<14:40:33> Main - Initialize network
<14:40:33> Net - Connection enabled in settings
<14:40:33> Net - System is connected to network
<14:40:33> Net - Try to establish server connection thread
<14:40:33> Net - Thread STARTED
<14:40:33> Main - Initialize network [DONE]
<14:40:33> Net - Choose server
<14:40:33> Net - Connect to [DL8]
<14:40:33> Main - Initialize PanBase
<14:40:33> Net - Server connection attempt #1
<14:40:33> Main - Initialize PanBase [DONE]
<14:40:33> Main - Initialize CPanel
<14:40:33> Cp - Cp Initialisation
<14:40:33> Main - Initialize CPanel [DONE]
<14:40:33> Cp - Try to compare server with local file
<14:40:33> Conf - Hardware Scan:
<14:40:33> Conf - CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz, Speed: 1190, Cores: 8
<14:40:33> Conf - GPU: Intel(R) UHD Graphics, Memory: 1 GB
<14:40:33> Conf - RAM: 15 GB
<14:40:33> Conf - DISC: 217656 MB
<14:40:33> Cp - Connection port: 80
<14:40:33> Cp - Connection default port: True
<14:40:33> Cp - Connection proxy bypassed: True
<14:40:33> Cp - Connection OK
<14:40:33> Cp - 22/12/2020 13:58:21 24/12/2023 10:59:34
<14:40:33> Cp - Up-to-date
<14:40:33> Cp - Check Cp file
<14:40:33> Cp - Abort: Cp file to short
<14:40:41> Conf - Save conf file
<14:40:41> Conf - Save conf file [DONE]
<14:40:41> Exit(A)
Log started at 2023/12/24 15:11:54
Release ID: A65
NET Versions:
Language: EN
Steam status: True
Master found: True
SKSE found: False
> Start logging:
<15:11:54> Conf - Initialize conf file
<15:11:54> Conf - Unpack Readme
<15:11:54> Conf - Initialize conf file [DONE]
<15:11:54> Conf - Save conf file
<15:11:54> Conf - Save conf file [DONE]
<15:11:54> Conf - Checking Environment
<15:11:54> Conf - Checking Environment [DONE]
<15:11:54> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\EnderalLauncher\system\ recursive
<15:11:54> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\EnderalLauncher\update\ recursive
<15:11:54> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\EnderalLauncher\backup\ top level
<15:11:54> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\ top level
<15:11:54> Main - Initialize Unpatcher
<15:11:54> Main - Unpatcher [DONE]
<15:11:54> Main - Create environment
<15:11:54> Main - Create environment [DONE]
<15:11:54> Main - REG ENTRY
<15:11:54> Main - Initialize network
<15:11:54> Net - Connection enabled in settings
<15:11:54> Net - System is connected to network
<15:11:54> Net - Try to establish server connection thread
<15:11:54> Net - Thread STARTED
<15:11:54> Main - Initialize network [DONE]
<15:11:54> Net - Choose server
<15:11:54> Main - Initialize intervall [DONE]
<15:11:54> Net - Connect to [DL5]
<15:11:54> Main - Initialize PanBase
<15:11:54> Main - Initialize PanBase [DONE]
<15:11:54> Main - Initialize CPanel
<15:11:54> Cp - Cp Initialisation
<15:11:54> Main - Initialize CPanel [DONE]
<15:11:54> Cp - Try to compare server with local file
<15:11:54> Conf - Hardware Scan:
<15:11:54> Conf - CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz, Speed: 1190, Cores: 8
<15:11:54> Conf - GPU: Intel(R) UHD Graphics, Memory: 1 GB
<15:11:54> Conf - RAM: 15 GB
<15:11:54> Conf - DISC: 217656 MB
<15:11:54> Cp - Connection port: 80
<15:11:54> Cp - Connection default port: True
<15:11:54> Cp - Connection proxy bypassed: True
<15:11:54> Cp - Connection OK
<15:11:54> Cp - 22/12/2020 13:58:21 24/12/2023 10:59:34
<15:11:54> Cp - Up-to-date
<15:11:54> Cp - Check Cp file
<15:11:54> Cp - Abort: Cp file to short
<15:11:57> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<15:12:09> Conf - Save conf file
<15:12:09> Conf - Save conf file [DONE]
<15:12:09> Exit(A)
Log started at 2023/12/24 16:22:35
Release ID: A65
NET Versions:
Language: EN
Steam status: True
Master found: True
SKSE found: False
> Start logging:
<16:22:36> Conf - Initialize conf file
<16:22:36> Conf - Unpack Readme
<16:22:36> Conf - Initialize conf file [DONE]
<16:22:36> Conf - Save conf file
<16:22:36> Conf - Save conf file [DONE]
<16:22:36> Conf - Checking Environment
<16:22:36> Conf - Checking Environment [DONE]
<16:22:36> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\EnderalLauncher\system\ recursive
<16:22:36> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\EnderalLauncher\update\ recursive
<16:22:36> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\EnderalLauncher\backup\ top level
<16:22:36> Func - RWP: G:\ESTIM DOS\steamapps\common\Enderal Special Edition\ top level
<16:22:36> Main - Initialize Unpatcher
<16:22:36> Main - Unpatcher [DONE]
<16:22:36> Main - Create environment
<16:22:36> Main - Create environment [DONE]
<16:22:36> Main - REG ENTRY
<16:22:36> Main - Initialize network
<16:22:36> Net - Connection enabled in settings
<16:22:36> Net - System is connected to network
<16:22:36> Net - Try to establish server connection thread
<16:22:36> Net - Thread STARTED
<16:22:36> Main - Initialize network [DONE]
<16:22:36> Net - Choose server
<16:22:36> Main - Initialize intervall [DONE]
<16:22:36> Net - Server connection attempt #1
<16:22:36> Main - Initialize PanBase [DONE]
<16:22:36> Main - Initialize CPanel
<16:22:36> Cp - Cp Initialisation
<16:22:36> Main - Initialize CPanel [DONE]
<16:22:36> Cp - Try to compare server with local file
<16:22:36> Conf - Hardware Scan:
<16:22:36> Conf - CPU: Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz, Speed: 1190, Cores: 8
<16:22:36> Conf - GPU: Intel(R) UHD Graphics, Memory: 1 GB
<16:22:36> Conf - RAM: 15 GB
<16:22:36> Conf - DISC: 217656 MB
<16:22:36> Cp - Connection port: 80
<16:22:36> Cp - Connection default port: True
<16:22:36> Cp - Connection proxy bypassed: True
<16:22:36> Cp - Connection OK
<16:22:36> Cp - 22/12/2020 13:58:21 24/12/2023 10:59:34
<16:22:36> Cp - Up-to-date
<16:22:36> Cp - Check Cp file
<16:22:36> Cp - Abort: Cp file to short
<16:22:44> Conf - Save conf file
<16:22:44> Conf - Save conf file [DONE]
<16:22:44> Exit(A)Everything looks okay
. Just like your other attempts.
But you haven't installed skse separately manually (or any mods)?
A customised skse version is already integrated in the game.
I only installed SKSE from Steam (I knew it wasn't necessary but I had to try it just in case) and no other mods. It's a bummer, I really wanted to play this, and I bought SK for that sole purpose as I've already given it a thousand spins on PS3.
Thank you so much Kermit for taking the time to look into it.
https://www.dropbox.com/scl/fi/sd6wraiy ... ztk1v&dl=0
Yes, Enderal requires SKSE.
However, it must/may not be installed manually as it is already integrated.
Other SKSE versions lead to errors.
But you are not the first to experience this
So reinstall Enderal SE (without manual SKSE version) and it should work.
One more note: if you want to install mods, it's best to limit yourself to those written for Enderal SE (yes I know there are some compatible Skyrim mods).
