6 posts • Page 1 of 1
Good day!!
A similar problem has already been on the forum, but all the solutions I know did not give a positive result.
I tried restarting all tracks via the console using the commands "help silence" and "removemusic _00E...". But the battle music still didn't play. And there are no old saves left. Please help me solve the problem.
hi, welcome to the forum!
could you tell us a bit more about what exactly you tried already?
- did you try to let Steam verify your game files
- do you have any mods installed?
(remove them and try without)
(- just to rule that out - please check the audiosettings)
if that doesn't help, please attach a savegame (no auto- or quicksave).
depending on your version they're found in (...\Documents\My Games\Enderal) or (...\Documents\My Games\Enderal Special Edition)
we'll need the *.ess and the *.skse file; pack both to a zip/rar/whatever archive (the forum doesn't accept *.skse).
thank you :)
Hello!
I verified the game files in Steam. Also, no mods are installed.
I found a topic on a forum where a similar problem was raised. Most likely, there is no problem with combat music. The point, I suppose, is my high level of hero. The enemies are too weak for me. In this case, the music shouldn't be playing, right?
Thank you very much!
hey,
you're most likely correct with the "enemies are to weak" assumption.
but - we couldn't load your save, so i ran it through the save game cleaner (which worked).
there was no combat music in the loaded area, but it worked in the Frostcliff Mountains.
you might want to teleport to some high level area and test the combat music over there, it could very well play.
i'll upload the "fixed" save in any case (since there were some errors).
hope that helps :)
saves.zip
(2.66 MiB) Downloaded 291 times
Good evening!
Thank you so much for your help.
hi!
i linked the Save cleaner above (maybe the formatting doesn't show it)
https://www.nexusmods.com/skyrim/mods/52363/
it's made for Skyrim but it works really well with Enderal as well.
you can absolutely try it yourself :)
what showed in the save weren't "errors" in a mean, evil, bad way; your save is already fairly "old" and big (congrats btw ;) )
and sometimes scripts/object references just don't get deleted and "hang around" (, maybe even bloating the save)
[+] the full log
Removing scripts attached to the nonexistent created forms..
FF000F05: ObjectReference
FF000F73: ObjectReference
FF000E73: ObjectReference
FF000F0B: ObjectReference
FF000F1C: ObjectReference
FF000CE8: Package
FF000CE8: ObjectReference
FF000F1D: ObjectReference
FF000CE9: ObjectReference
FF000CEA: ObjectReference
FF000F1B: ObjectReference
FF000F1B: Package
FF000CDD: ObjectReference
FF000F1A: ObjectReference
FF000E6A: ObjectReference
FF000D68: ObjectReference
FF000D6A: ObjectReference
FF000CD9: ObjectReference
FF000F12: Package
FF000CE4: ObjectReference
FF000CE5: ObjectReference
FF000C5B: ObjectReference
FF000D66: ObjectReference
FF000CE3: ObjectReference
FF000838: Form
FF000838: Potion
FF000CC6: ObjectReference
FF000F37: ObjectReference
FF000CD7: ObjectReference
FF000CE2: ObjectReference
FF000D64: ObjectReference
FF000D22: ObjectReference
FF000CDA: ObjectReference
FF000D21: ObjectReference
34 script instances removed.
