Save folder being directed to SE Save folder, saving causes crashes?
4 Beiträge Seite 1 von 1
Jojash
Grünschnabel
Grünschnabel
Hello, been trying to play/mod Enderal lately, initially tried using Vortex to do this, but that caused some strange issues, which I suspect I'm still dealing with multiple clean installs and vanilla saves later. ^^;
On a clean install with no mods Enderal still uses the Skyrim SE save path. I have verified that the launcher for Enderal is correctly creating the inis and I've checked that they have the correct save file path. If I try to add any mods in this state, Enderal crashes when saving - using the .NET Script Framework mod suggests that this is being caused by an NPC names "Thara?l" - there's no NPC called that nearby, so I'm assuming they exist somewhere out of view for some kind of scripting purpose.
My working hypothesis is that there's a file somewhere overwriting the dll (Skyrim Redirector?) that tells Enderal to use its own inis, but that feels insane after mutliple clean installs, etc.
I have been directed to check this for solutions: https://steamcommunity.com/app/976620/d ... 771533910/ and have followed as many of the subsections (2.1 and 2.2) as I was able and as I said before, those fixes were suggested to me specifically to generate the ini files, which I've confirmed are being correctly generated.
Any help would be appreciated, thanks in advance!
Full crash log here:
[+] Log
Unhandled native exception occurred at 0xFFFFFF0024A48D48 on thread 25228!
FrameworkName: NetScriptFramework
FrameworkVersion: 15
FrameworkArchitecture: x64
GameLibrary: SkyrimSE
GameLibraryVersion: 18
ApplicationName: SkyrimSE.exe
ApplicationVersion: 1.5.97.0
VersionInfo: Successfully loaded
Time: 13 May 2023 05:00:16.534
Possible relevant objects (2)
[ 179] TESNPC(Name: `Thara?l`, FormId: 0502F38C, File: `Enderal - Forgotten Stories.esm`)
[ 179] Character(FormId: 0502F38D, File: `Enderal - Forgotten Stories.esm`, BaseForm: TESNPC(Name: `Thara?l`, FormId: 0502F38C, File: `Enderal - Forgotten Stories.esm`))
Probable callstack
[0] 0xFFFFFF0024A48D48
[1] 0x7FFC024B71C3 (SkyrimRedirector.dll+71C3)
[2] 0x22F562C2720
[3] 0xBE1
[4] 0x895640E178BE
[5] 0x8F
[6] 0x3EE
[7] 0x7FFB9524C8AE (usvfs_x64.dll+4C8AE)
[8] 0x7FFC0000049C
[9] 0x22F3BFE0FB0
Registers
AX: 0xFFFFFF0024A48D48 (i64):[-1098896863928]
BX: 0x7FFB9530E300 (usvfs_x64.dll+10E300) (char*) "usvfs::hook_DeleteFileW"
CX: 0x22F562C2720 (char*) "C"
DX: 0x50 (u8):[80]
SI: 0x8F (u8):[143]
DI: 0x22F562C2720 (char*) "C"
BP: 0x3EE (u16):[1006]
SP: 0x8D8278E008 (void*)
IP: 0xFFFFFF0024A48D48 (i64):[-1098896863928]
R8: 0x53 (u8):[83]
R9: 0x73 (u8):[115]
R10: 0x22F562C27A0 (char*) "a"
R11: 0x7FFC024DA982 (SkyrimRedirector.dll+2A982) (char*) "L"
R12: 0xBE1 (u16):[3041]
R13: 0x22F1D228480 (void*)
R14: 0x0 (NULL)
R15: 0x0 (NULL)
Flags: 0x10246
XMM0: (double)1.18613148779272E-311 / (float)-1.577922E+34
XMM1: (double)2.32210853545386E-322 / (float)6.586103E-44
XMM2: (double)2.55888926350986E-307 / (float)1.11122E-38
XMM3: (double)6.89810922845783E-307 / (float)9.642873E-39
XMM4: (double)8.90072832751657E-308 / (float)4.500014E-39
XMM5: (double)8.90073681537021E-308 / (float)4.408175E-39
XMM6: (double)5.01763588302561E-315 / (float)0.01666667
XMM7: (double)0 / (float)0
XMM8: (double)5.01763588302561E-315 / (float)0.01666667
XMM9: (double)0 / (float)0
XMM10: (double)7.91603898582748E-315 / (float)1.844674E+19
XMM11: (double)0 / (float)0
XMM12: (double)0 / (float)0
XMM13: (double)0 / (float)0
XMM14: (double)0 / (float)0
XMM15: (double)0 / (float)0
Stack
[SP+0] 0x7FFC024B71C3 (SkyrimRedirector.dll+71C3) (void*)
[SP+8] 0x22F562C2720 (char*) "C"
[SP+10] 0xBE1 (u16):[3041]
[SP+18] 0x895640E178BE (u64):[151003548711102] (f32):[7.045989]
[SP+20] 0x8F (u8):[143]
[SP+28] 0x3EE (u16):[1006]
[SP+30] 0x7FFB9524C8AE (usvfs_x64.dll+4C8AE) (void*)
[SP+38] 0x22F562C2720 (char*) "C"
[SP+40] 0x7FFB9530E300 (usvfs_x64.dll+10E300) (char*) "usvfs::hook_DeleteFileW"
[SP+48] 0x8D8278E4A0 (SaveStorageWrapper*)
[SP+50] 0xBE1 (u16):[3041]
[SP+58] 0xFFFFFFFF00000000 (i64):[-4294967296]
[SP+60] 0x7FFC287C96FD (ntdll.dll+296FD) (void*)
[SP+68] 0x22F562C2720 (char*) "C"
[SP+70] 0x120 (u16):[288]
[SP+78] 0x8A (u8):[138]
[SP+80] 0x8F (u8):[143]
[SP+88] 0x20100000000 (u64):[2203318222848]
[SP+90] 0x22F00000008 (void*)
[SP+98] 0xFFFFFFFF00000000 (i64):[-4294967296]
[SP+A0] 0x22EF43F45C0 (void*)
[SP+A8] 0xFFFFFFFFFFFFFFFE (i64):[-2]
[SP+B0] 0x22EF43F0000 (void*)
[SP+B8] 0x120 (u16):[288]
[SP+C0] 0x22EF43F02E8 (void*)
[SP+C8] 0x22EF43F0D80 (void*)
[SP+D0] 0x7FFB9523BA80 (usvfs_x64.dll+3BA80) (void*)
[SP+D8] 0x22EF462BE50 (void*)
[SP+E0] 0x118 (u16):[280]
[SP+E8] 0x0 (NULL)
[SP+F0] 0x22EF4639078 (void*)
[SP+F8] 0x22F1D228480 (void*)
[SP+100] 0xBE1 (u16):[3041]
[SP+108] 0x22F562C2980 (char*) "C"
[SP+110] 0x0 (NULL)
[SP+118] 0x8A (u8):[138]
[SP+120] 0x8F (u8):[143]
[SP+128] 0x22F562C3560 (char*) "C"
[SP+130] 0x30 (u8):[48]
[SP+138] 0x8A (u8):[138]
[SP+140] 0x8F (u8):[143]
[SP+148] 0x0 (NULL)
[SP+150] 0x22F562C2980 (char*) "C"
[SP+158] 0x200000000 (u64):[8589934592]
[SP+160] 0x1 (u8):[1]
[SP+168] 0x1 (u8):[1]
[SP+170] 0x7FF7984F1C0D (SkyrimSE.exe+1251C0D) (void*)
[SP+178] 0x22F562C0000 (void*)
[SP+180] 0x7FFB952C6D5A (usvfs_x64.dll+C6D5A) (void*)
[SP+188] 0x0 (NULL)
[SP+190] 0x7 (u8):[7]
[SP+198] 0x22F562C0000 (void*)
[SP+1A0] 0x0 (NULL)
[SP+1A8] 0x0 (NULL)
[SP+1B0] 0x7 (u8):[7]
[SP+1B8] 0x22E9BB7AB80 (void*)
[SP+1C0] 0x1 (u8):[1]
[SP+1C8] 0x895640E146EE (u64):[151003548698350] (f32):[7.039908]
[SP+1D0] 0x7FFB94EB3148 (skse64_1_5_97.dll+123148) (char**) "54F6639B385, os = 6.2 (9200))\nimagebase = 00007FF7972A0000\nreloc mgr imagebase = 00007FF7972A0000\nconfig path = D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\skse.ini\nplugin directory = D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\nchecking plugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\EnderalSE.dll\nregistering plugin listener for SKSE at 1 of 2\nplugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\EnderalSE.dll (00000001 EnderalSE 01010000) loaded correctly (handle 1)\nchecking plugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\EngineFixes.dll\nregistering plugin listener for SKSE at 2 of 3\nplugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\EngineFixes.dll (00000001 EngineFixes plugin 00000005) loaded correctly (handle 2)\nchecking plugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\fs_steam.dll\nplugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\fs_steam.dll (00000001 EnderalSteam 01000010) loaded correctly (handle 3)\nchecking plugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\JContainers64.dll\nregistering plugin listener for SKSE at 4 of 5\nplugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\JContainers64.dll (00000001 JContainers64 00000004) loaded correctly (handle 4)\nchecking plugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\SkyrimRedirector.dll\nplugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\SkyrimRedirector.dll (00000001 Skyrim Redirector 00000001) loaded correctly (handle 5)\nchecking plugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\SSEDisplayTweaks.dll\nregistering plugin listener for SKSE at 6 of 7\nplugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\SSEDisplayTweaks.dll (00000001 SSEDisplayTweaks 0000050A) loaded correctly (handle 6)\nchecking plugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\YesImSure.dll\nplugin D:\SteamLibrary\steamapps\common\Enderal Special Edition\Data\SKSE\Plugins\\YesImSure.dll (00000001 YesImSure 00000001) loaded correctly (handle 7)\ndispatch message (0) to plugin listeners\ndispatch message (1) to plugin listeners\ndispatch message (1) to plugin listeners\ninit complete\nhooked dinput\ndispatch message (6) to plugin listeners\nReading translations from Interface\Translations\SkyUI_SE_ENGLISH.txt...\ndispatch message (8) to plugin listeners\nsetting not found (bFreebiesSeen:General)\nsave name is Save3_45822034_0_566F6C757361_MQP02StartShip_000014_20230513025837_1_1\nfull save path: C:\Users\Jojas\Documents\My Games\Skyrim Special Edition\Saves\\Save3_45822034_0_566F6C757361_MQP02StartShip_000014_20230513025837_1_1.skse\ndispatch message (2) to plugin listeners\nloading co-save\nLoading plugin list:\n\t(0 -> 0)\tSkyrim.esm\n\t(1 -> 1)\tDawnguard.esm\n\t(2 -> 2)\tHearthFires.esm\n\t(3 -> 3)\tDragonborn.esm\n\t(4 -> 4)\tUpdate.esm\n\t(5 -> 5)\tEnderal - Forgotten Stories.esm\n\t(6 -> 6)\tSkyUI_SE.esp\nLoading menu open/close event registrations...\nLoading key input event registrations...\nLoading control input event registrations...\nLoading mod callback event registrations...\nLoading crosshair ref event registrations...\nLoading camera event registrations...\nLoading actor action event registrations...\nLoading NiNode update event registrations...\nLoading SKSEPersistentObjectStorage data...\nLoading SKSEDelayFunctorManager data...\ndispatch message (3) to plugin listeners\ncleared save path\nWidgetLoader.as: setRootPath(a_path = exported/)\nWidgetLoader.as: loadWidget(a_widgetID = 0, a_widgetSource = skyui/followerpanel.swf)\nWidgetLoader.as: loadWidget(a_widgetID = 1, a_widgetSource = skyui/activeeffects.swf)\nsave name is Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1\nfull save path: C:\Users\"
[SP+1D8] 0x0 (NULL)
[SP+1E0] 0x7FFB952923AA (usvfs_x64.dll+923AA) (void*)
[SP+1E8] 0x22E00000000 (u64):[2396591751168]
[SP+1F0] 0x0 (NULL)
[SP+1F8] 0x22EF463E4A8 (void*)
[SP+200] 0x7FFC024DA980 (SkyrimRedirector.dll+2A980) (char*) "P"
[SP+208] 0x0 (NULL)
[SP+210] 0x8D8278E2F0 (char*) "?"
[SP+218] 0x8D8278E4A0 (SaveStorageWrapper*)
[SP+220] 0x7FF79A1C7E80 (SkyrimSE.exe+2F27E80) (SkyrimVM*)
[SP+228] 0x3EE (u16):[1006]
[SP+230] 0x7FFC00000466 (char*) "H?? A_A^A]A\A[AZAYAX_^][ZY?H??"
[SP+238] 0x7FFC2630B230 (KERNELBASE.dll+8B230) (void*)
[SP+240] 0x22EF4639078 (void*)
[SP+248] 0x7FFB94EB4B78 (skse64_1_5_97.dll+124B78) (char**) "C:\Users\Jojas\Documents\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.skse"
[SP+250] 0x7FFC024B7E55 (SkyrimRedirector.dll+7E55) (void*)
[SP+258] 0x0 (NULL)
[SP+260] 0x22EF4639078 (void*)
[SP+268] 0x22F1D228480 (void*)
[SP+270] 0xBE1 (u16):[3041]
[SP+278] 0x7FFC024DA982 (SkyrimRedirector.dll+2A982) (char*) "L"
[SP+280] 0x22F3BFE1032 (char*) "a"
[SP+288] 0x73 (u8):[115]
[SP+290] 0x53 (u8):[83]
[SP+298] 0x8D8278E4A0 (SaveStorageWrapper*)
[SP+2A0] 0x7FF79A1C7E80 (SkyrimSE.exe+2F27E80) (SkyrimVM*)
[SP+2A8] 0x3EE (u16):[1006]
[SP+2B0] 0x22EF4639078 (void*)
[SP+2B8] 0x8D8278E4A0 (SaveStorageWrapper*)
[SP+2C0] 0x7FF79A1C7E80 (SkyrimSE.exe+2F27E80) (SkyrimVM*)
[SP+2C8] 0x7FFB94EB4B78 (skse64_1_5_97.dll+124B78) (char**) "C:\Users\Jojas\Documents\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.skse"
[SP+2D0] 0x7FFC0000049C (char*) "P?QRSUVWAPAQARASATAUAVAWH?0?0&?"
[SP+2D8] 0x22F3BFE0FB0 (char*) "C"
[SP+2E0] 0x0 (NULL)
[SP+2E8] 0x8C008B (u32):[9175179]
[SP+2F0] 0x22F3EAD65C0 (char*) "C:\Users\Jojas\Documents\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.skse"
[SP+2F8] 0x7FFB94EB4B78 (skse64_1_5_97.dll+124B78) (char**) "C:\Users\Jojas\Documents\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.skse"
[SP+300] 0x7FFC2630B201 (KERNELBASE.dll+8B201) (void*)
[SP+308] 0x22F3BFE0FB0 (char*) "C"
[SP+310] 0x7FFC024DAA18 (SkyrimRedirector.dll+2AA18) (char*) "PLUGINS.TXT"
[SP+318] 0x7FFB94EC35C0 (skse64_1_5_97.dll+1335C0) (void*)
[SP+320] 0x0 (NULL)
[SP+328] 0x22F01180116 (void*)
[SP+330] 0x22F3BFE0FB0 (char*) "C"
[SP+338] 0x7FFB94EB4B78 (skse64_1_5_97.dll+124B78) (char**) "C:\Users\Jojas\Documents\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.skse"
[SP+340] 0x7FFC024B7193 (SkyrimRedirector.dll+7193) (void*)
[SP+348] 0x22F3EAD65C0 (char*) "C:\Users\Jojas\Documents\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.skse"
[SP+350] 0x3EE (u16):[1006]
[SP+358] 0x7FF79A1C7E80 (SkyrimSE.exe+2F27E80) (SkyrimVM*)
[SP+360] 0x8D8278E401 (void*)
[SP+368] 0x8D8278E4A0 (SaveStorageWrapper*)
[SP+370] 0x7FFB94E16521 (skse64_1_5_97.dll+86521) (void*)
[SP+378] 0x22F3EAD65C0 (char*) "C:\Users\Jojas\Documents\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.skse"
[SP+380] 0x8D8278E2C0 (SaveStorageWrapper**)
[SP+388] 0x66 (u8):[102]
[SP+390] 0x7FFC0E1013AF (VCRUNTIME140.dll+13AF) (void*)
[SP+398] 0x22EF4639078 (void*)
[SP+3A0] 0x7FFB94D9F704 (skse64_1_5_97.dll+F704) (void*)
[SP+3A8] 0x8D00000001 (u64):[605590388737]
[SP+3B0] 0x1 (u8):[1]
[SP+3B8] 0x7FF79A1C7E80 (SkyrimSE.exe+2F27E80) (SkyrimVM*)
[SP+3C0] 0x8D8278E4A0 (SaveStorageWrapper*)
[SP+3C8] 0x5B (u8):[91]
[SP+3D0] 0x7FF797BCE3A5 (SkyrimSE.exe+92E3A5) (void*)
[SP+3D8] 0x7FF700000000 (u64):[140698833649664]
[SP+3E0] 0x5B (u8):[91]
[SP+3E8] 0x7FF79A1C8570 (SkyrimSE.exe+2F28570) (void*)
[SP+3F0] 0x3EE (u16):[1006]
[SP+3F8] 0xFFFFFFFFFFFFFFFE (i64):[-2]
[SP+400] 0x7FF79A1C7E80 (SkyrimSE.exe+2F27E80) (SkyrimVM*)
[SP+408] 0xD6643 (u32):[878147]
[SP+410] 0x8D8278E4A0 (SaveStorageWrapper*)
[SP+418] 0x0 (NULL)
[SP+420] 0x7FF797BCB769 (SkyrimSE.exe+92B769) (void*)
[SP+428] 0x7FF79896D7D0 (SkyrimSE.exe+16CD7D0) (void*)
[SP+430] 0x7FF79A1C7E80 (SkyrimSE.exe+2F27E80) (SkyrimVM*)
[SP+438] 0x5B (u8):[91]
[SP+440] 0x3E9 (u16):[1001]
[SP+448] 0x3E9 (u16):[1001]
[SP+450] 0x7FF797820A3F (SkyrimSE.exe+580A3F) (void*)
[SP+458] 0x1 (u8):[1]
[SP+460] 0x22F79D7F040 (anonymous_namespace::Win32FileType*)
[SP+468] 0x22F79D7F040 (anonymous_namespace::Win32FileType*)
[SP+470] 0x3EE (u16):[1006]
[SP+478] 0xFFFFFFFFFFFFFFFE (i64):[-2]
[SP+480] 0x7FF7988E5960 (SkyrimSE.exe+1645960) (void*)
[SP+488] 0x22F50441400 (void*)
[SP+490] 0x400 (u16):[1024]
[SP+498] 0x7FF7988E5A00 (SkyrimSE.exe+1645A00) (void*)
[SP+4A0] 0xFFFD1F0000000000 (i64):[-810340069670912]
[SP+4A8] 0x22F79CEAA40 (void*)
[SP+4B0] 0x7FF797817F01 (SkyrimSE.exe+577F01) (void*)
[SP+4B8] 0x22F79D7F040 (anonymous_namespace::Win32FileType*)
[SP+4C0] 0xD6643 (u32):[878147]
[SP+4C8] 0x22EF4639078 (void*)
[SP+4D0] 0xFF000824 (u32):[4278192164]
[SP+4D8] 0x3E (u8):[62]
[SP+4E0] 0x22F79D7F040 (anonymous_namespace::Win32FileType*)
[SP+4E8] 0x8D8278E600 (void*)
[SP+4F0] 0x7FF79781D0A3 (SkyrimSE.exe+57D0A3) (void*)
[SP+4F8] 0x46 (u8):[70]
[SP+500] 0x3E9 (u16):[1001]
[SP+508] 0x0 (NULL)
[SP+510] 0x22F00000002 (void*)
[SP+518] 0x6D3153400000004E (u64):[7868161558335979598]
[SP+520] 0x305F343301D9854F (u64):[3485562030287062351]
[SP+528] 0x7FF700000002 (u64):[140698833649666]
[SP+530] 0x22F502D90C0 (void*)
[SP+538] 0x22EF4638FE0 (ScrapHeap*)
[SP+540] 0x22F7242C0C0 (char*) "+"
[SP+548] 0xD000600000BE1 (u64):[3659200467045345]
[SP+550] 0x7FFB00000BE1 (u64):[140716013521889]
[SP+558] 0x22EF4639078 (void*)
[SP+560] 0x7FF7988E58E8 (SkyrimSE.exe+16458E8) (void*)
[SP+568] 0x22F721C5B80 (void*)
[SP+570] 0x13100008000 (u64):[1309965058048]
[SP+578] 0x41020000000F0300 (u64):[4684306562419720960] (f64):[147456.000028633]
[SP+580] 0x7FFB94EC354E (skse64_1_5_97.dll+13354E) (void*)
[SP+588] 0x22F4E7FC700 (Character*) -> (FormId: 0502F38D, File: `Enderal - Forgotten Stories.esm`, BaseForm: TESNPC(Name: `Thara?l`, FormId: 0502F38C, File: `Enderal - Forgotten Stories.esm`))
[SP+590] 0x7FFB94E4B558 (skse64_1_5_97.dll+BB558) (void*)
[SP+598] 0x0 (NULL)
[SP+5A0] 0x3D9B10003C14B (u64):[1083779162816843]
[SP+5A8] 0xD65690003DDFD (u64):[3770676343463421]
[SP+5B0] 0xE00000009 (u64):[60129542153]
[SP+5B8] 0xBDF00000000 (u64):[13052405612544]
[SP+5C0] 0x0 (NULL)
[SP+5C8] 0x0 (NULL)
[SP+5D0] 0x0 (NULL)
[SP+5D8] 0x0 (NULL)
[SP+5E0] 0x0 (NULL)
[SP+5E8] 0x0 (NULL)
[SP+5F0] 0x0 (NULL)
[SP+5F8] 0x200000000 (u64):[8589934592]
[SP+600] 0x7FFB94E4BCBE (skse64_1_5_97.dll+BBCBE) (void*)
[SP+608] 0xFFFFFFFFFFFFFFFE (i64):[-2]
[SP+610] 0x0 (NULL)
[SP+618] 0x35345F3465766153 (u64):[3833793861444329811]
[SP+620] 0x305F343330323238 (u64):[3485562031064625720]
[SP+628] 0x374336463636355F (u64):[3982086170710783327]
[SP+630] 0x514D5F3136333735 (u64):[5858443355246245685]
[SP+638] 0x7472617453323050 (u64):[8390876207984554064]
[SP+640] 0x3030305F70696853 (u64):[3472328499168634963]
[SP+648] 0x333230325F343130 (u64):[3689064037673611568]
[SP+650] 0x3030343033313530 (u64):[3472332694324589872]
[SP+658] 0x652E315F315F3631 (u64):[7290819131679389233]
[SP+660] 0x7FFB94007373 (u64):[140718496576371]
[SP+668] 0x3 (u8):[3]
[SP+670] 0x0 (NULL)
[SP+678] 0x0 (NULL)
[SP+680] 0x7FFB94E82048 (skse64_1_5_97.dll+F2048) (char*) "SKSE"
[SP+688] 0x22F79D7FAF0 (char*) "Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1"
[SP+690] 0x46 (u8):[70]
[SP+698] 0x1 (u8):[1]
[SP+6A0] 0x7FFB94E45CC3 (skse64_1_5_97.dll+B5CC3) (void*)
[SP+6A8] 0x8D00000003 (u64):[605590388739]
[SP+6B0] 0x22EFD83A7D0 (char**) "\nreating co-savege.e 4 to plugin 6teners\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.sksely (handle 6))"
[SP+6B8] 0x22EFDAE40D0 (char*) "\nreating co-savege.e 4 to plugin 6teners\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.sksely (handle 6))"
[SP+6C0] 0x8D8278E718 (void*)
[SP+6C8] 0x8D8278E798 (void*)
[SP+6D0] 0x7FFB94E45D11 (skse64_1_5_97.dll+B5D11) (void*)
[SP+6D8] 0x22EFD83A7D0 (char**) "\nreating co-savege.e 4 to plugin 6teners\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.sksely (handle 6))"
[SP+6E0] 0x8D8278E828 (void*)
[SP+6E8] 0x8D8278E740 (char*) "3 05:00:16, EXE Version: 1.5.97.0, Save Version 12.78"
[SP+6F0] 0x1 (u8):[1]
[SP+6F8] 0x0 (NULL)
[SP+700] 0x7FFB94E45C0B (skse64_1_5_97.dll+B5C0B) (void*)
[SP+708] 0x7FFB94EC090A (skse64_1_5_97.dll+13090A) (void*)
[SP+710] 0x22EFD83A7D0 (char**) "\nreating co-savege.e 4 to plugin 6teners\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.sksely (handle 6))"
[SP+718] 0x8D8278E790 (void*)
[SP+720] 0x8D8278E828 (void*)
[SP+728] 0x202D2073616A6F4A (u64):[2318545063093366602]
[SP+730] 0x3230322F33312F35 (u64):[3616445679082221365]
[SP+738] 0x3A30303A35302033 (u64):[4192904279640514611]
[SP+740] 0x20455845202C3631 (u64):[2325361836522485297]
[SP+748] 0x3A6E6F6973726556 (u64):[4210425200337118550]
[SP+750] 0x2E37392E352E3120 (u64):[3330193320087269664]
[SP+758] 0x2065766153202C30 (u64):[2334402142239992880]
[SP+760] 0x206E6F6973726556 (u64):[2336927755350992214]
[SP+768] 0x38372E3231 (u64):[241443942961]
[SP+770] 0x7FFB94E192D4 (skse64_1_5_97.dll+892D4) (void*)
[SP+778] 0x22EFDB81A00 (void*)
[SP+780] 0x22EFD83A7D0 (char**) "\nreating co-savege.e 4 to plugin 6teners\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.sksely (handle 6))"
[SP+788] 0x22EFD83A7D0 (char**) "\nreating co-savege.e 4 to plugin 6teners\My Games\Skyrim Special Edition\Saves\\Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1.sksely (handle 6))"
[SP+790] 0x8D8278E788 (void*)
[SP+798] 0xFFFFFF01 (u32):[4294967041]
[SP+7A0] 0x7FFB94E190BA (skse64_1_5_97.dll+890BA) (void*)
[SP+7A8] 0x22EFDB81A00 (void*)
[SP+7B0] 0x7FFB94EC0930 (skse64_1_5_97.dll+130930) (char*) "creating co-save"
[SP+7B8] 0x8D8278E828 (void*)
[SP+7C0] 0x0 (NULL)
[SP+7C8] 0x0 (NULL)
[SP+7D0] 0x8D8278E828 (void*)
[SP+7D8] 0xFFFFFFFF (u32):[4294967295]
[SP+7E0] 0x7FFB94E11E1A (skse64_1_5_97.dll+81E1A) (void*)
[SP+7E8] 0x22EFDB81A20 (char*) "\"
[SP+7F0] 0x4 (u8):[4]
[SP+7F8] 0x4 (u8):[4]
[SP+800] 0x46 (u8):[70]
[SP+808] 0xFFFFFFFF (u32):[4294967295]
[SP+810] 0x7FFB94E111A2 (skse64_1_5_97.dll+811A2) (void*)
[SP+818] 0x7FFB94E88548 (skse64_1_5_97.dll+F8548) (char*) "dispatched message."
[SP+820] 0x8D8278E840 (char**) "SKSE"
[SP+828] 0xD301E6EF1629AD3 (u64):[950292983220181715]
[SP+830] 0x0 (NULL)
[SP+838] 0x7FFB94E82048 (skse64_1_5_97.dll+F2048) (char*) "SKSE"
[SP+840] 0x8D8278E9B0 (char*) "Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1"
[SP+848] 0x22F5741D000 (void*)
[SP+850] 0x22F1CEA20C0 (char*) "4 ?E"
[SP+858] 0x8D8278EB00 (void*)
[SP+860] 0x22F79D7F040 (anonymous_namespace::Win32FileType*)
[SP+868] 0x22F1D228480 (void*)
[SP+870] 0x22F79D7FAF0 (char*) "Save4_45822034_0_566F6C757361_MQP02StartShip_000014_20230513040016_1_1"
[SP+878] 0x8D8278E9D0 (char*) "P02StartShip_000014_20230513040016_1_1"
[SP+880] 0x7FFB94DA044E (skse64_1_5_97.dll+1044E) (void*)
[SP+888] 0x22F5741D04E (void*)
[SP+890] 0x8D0003C0E7 (u64):[605590634727]
[SP+898] 0x22F00000001 (void*)
[SP+8A0] 0x22F00000046 (void*)
[SP+8A8] 0x0 (NULL)
[SP+8B0] 0x22F7FEA2200 (void*)
[SP+8B8] 0x2 (u8):[2]
[SP+8C0] 0x7FF797826F70 (SkyrimSE.exe+586F70) (void*)
[SP+8C8] 0x3C068 (u32):[245864]
[SP+8D0] 0x22F1D26B800 (BGSSaveLoadManager*)
[SP+8D8] 0x22F00000000 (void*)
[SP+8E0] 0x8D44F9C000 (u64):[606747607040] (f32):[1998]
[SP+8E8] 0x2 (u8):[2]
[SP+8F0] 0x8D8278EAE0 (void*)
[SP+8F8] 0x22F79D7F040 (anonymous_namespace::Win32FileType*)
[SP+900] 0x8D8278EFE8 (anonymous_namespace::LoggingDisabler**)
[SP+908] 0x22F00000000 (void*)
[SP+910] 0x22F8050D168 (void*)
[SP+918] 0x22F8001A320 (void*)
[SP+920] 0x22F8050D168 (void*)
[SP+928] 0x22F7FEFBD18 (void*)
[SP+930] 0x7FF700000002 (u64):[140698833649666]
[SP+938] 0x22F8006B260 (void*)
[SP+940] 0x22F00000000 (void*)
[SP+948] 0xFFFFFFFFFFFFFFFE (i64):[-2]
[SP+950] 0xF (u8):[15]
[SP+958] 0x22F80519CC0 (void*)
[SP+960] 0x7FF7011A5FA9 (u64):[140698852155305]
[SP+968] 0x22F8050D168 (void*)
[SP+970] 0x22F8050D000 (void*)
[SP+978] 0x22F80427000 (void*)
[SP+980] 0x0 (NULL)
[SP+988] 0xE3E00000E3E (u64):[15659450764862]
[SP+990] 0x8D00000E3E (u64):[605590392382]
[SP+998] 0x22F803B9CC0 (void*)
[SP+9A0] 0x22F7FEF9380 (void*)
[SP+9A8] 0x35345F3465766153 (u64):[3833793861444329811]
[SP+9B0] 0x305F343330323238 (u64):[3485562031064625720]
[SP+9B8] 0x374336463636355F (u64):[3982086170710783327]
[SP+9C0] 0x514D5F3136333735 (u64):[5858443355246245685]
[SP+9C8] 0x7472617453323050 (u64):[8390876207984554064]
[SP+9D0] 0x3030305F70696853 (u64):[3472328499168634963]
[SP+9D8] 0x333230325F343130 (u64):[3689064037673611568]
[SP+9E0] 0x3030343033313530 (u64):[3472332694324589872]
[SP+9E8] 0x315F315F3631 (u64):[54284919977521]
[SP+9F0] 0x0 (NULL)
[SP+9F8] 0x0 (NULL)
[SP+A00] 0x0 (NULL)
[SP+A08] 0x0 (NULL)
[SP+A10] 0x0 (NULL)
[SP+A18] 0x0 (NULL)
[SP+A20] 0x0 (NULL)
[SP+A28] 0x0 (NULL)
[SP+A30] 0x0 (NULL)
[SP+A38] 0x0 (NULL)
[SP+A40] 0x0 (NULL)
[SP+A48] 0x0 (NULL)
[SP+A50] 0x0 (NULL)
[SP+A58] 0x0 (NULL)
[SP+A60] 0x0 (NULL)
[SP+A68] 0x0 (NULL)
[SP+A70] 0x0 (NULL)
[SP+A78] 0x0 (NULL)
[SP+A80] 0x0 (NULL)
[SP+A88] 0x0 (NULL)
[SP+A90] 0x0 (NULL)
[SP+A98] 0x0 (NULL)
[SP+AA0] 0x0 (NULL)
[SP+AA8] 0x22F00000000 (void*)
[SP+AB0] 0x8D8278F118 (void*)
[SP+AB8] 0x22F5741D000 (void*)
[SP+AC0] 0x22F5741D000 (void*)
[SP+AC8] 0x0 (NULL)
[SP+AD0] 0x8D8278EBF0 (void*)
[SP+AD8] 0x8D8278EBF0 (void*)
[SP+AE0] 0x22F721D2098 (Journal_SystemTab*)
[SP+AE8] 0x8D8278EB80 (void*)
[SP+AF0] 0x7FF798176D18 (SkyrimSE.exe+ED6D18) (void*)
[SP+AF8] 0x22F7FEA22E0 (Journal_SystemTab**)
[SP+B00] 0x8D8278EBF0 (void*)
[SP+B08] 0x0 (NULL)
[SP+B10] 0x0 (NULL)
[SP+B18] 0xFFFFFFFFFFFFFFFE (i64):[-2]
[SP+B20] 0x0 (NULL)
[SP+B28] 0x3 (u8):[3]
[SP+B30] 0x4032000000000000 (u64):[4625759767262920704] (f64):[18]
[SP+B38] 0x0 (NULL)
[SP+B40] 0x22F00000003 (void*)
[SP+B48] 0x4032000000000000 (u64):[4625759767262920704] (f64):[18]
[SP+B50] 0x22F721D2098 (Journal_SystemTab*)
[SP+B58] 0x22F5741D000 (void*)
[SP+B60] 0x8D8278EC08 (void*)
[SP+B68] 0x22F00000001 (void*)
[SP+B70] 0x2 (u8):[2]
[SP+B78] 0x2 (u8):[2]
[SP+B80] 0x8D8278EC20 (void*)
[SP+B88] 0x8D8278EE29 (void*)
[SP+B90] 0x7FF798258D17 (SkyrimSE.exe+FB8D17) (void*)
[SP+B98] 0x8D8278EB28 (void*)
[SP+BA0] 0x22F7FFFDF50 (char*) "?"
[SP+BA8] 0x22F7FFE00A0 (char*) "SaveGame"
[SP+BB0] 0x8D8278EDB0 (void*)
[SP+BB8] 0x8D00000002 (u64):[605590388738]
[SP+BC0] 0x22F8050D258 (void*)
[SP+BC8] 0x22F7FFFDF50 (char*) "?"
[SP+BD0] 0x0 (NULL)
[SP+BD8] 0x0 (NULL)
[SP+BE0] 0x1500000001 (u64):[90194313217]
[SP+BE8] 0x0 (NULL)
[SP+BF0] 0x7FF700000003 (u64):[140698833649667]
[SP+BF8] 0x4032000000000000 (u64):[4625759767262920704] (f64):[18]
[SP+C00] 0x0 (NULL)
[SP+C08] 0x7FF700000003 (u64):[140698833649667]
[SP+C10] 0x0 (NULL)
[SP+C18] 0x0 (NULL)
[SP+C20] 0x8D8278EE68 (void*)
[SP+C28] 0x22F8050D168 (void*)
[SP+C30] 0x7FF7981A1AEA (SkyrimSE.exe+F01AEA) (void*)
[SP+C38] 0x22F804F7000 (void*)
[SP+C40] 0x22F804F7000 (void*)
[SP+C48] 0x8D8278ECA9 (void*)
[SP+C50] 0x8D8278EE68 (void*)
[SP+C58] 0x22F801D0000 (char*) "?"
[SP+C60] 0x22F7FEFBC80 (void*)
[SP+C68] 0x0 (NULL)
[SP+C70] 0x22F804F66D0 (char**) "length"
[SP+C78] 0x22F7FFF8630 (void*)
[SP+C80] 0x7FF798182FC7 (SkyrimSE.exe+EE2FC7) (void*)
[SP+C88] 0x8D8278ED80 (void*)
[SP+C90] 0x8D8278EE40 (void*)
[SP+C98] 0x22F804F2060 (void*)
[SP+CA0] 0x1 (u8):[1]
[SP+CA8] 0x8D8278EDCE (void*)
[SP+CB0] 0x2B594 (u32):[177556]
[SP+CB8] 0x1 (u8):[1]
[SP+CC0] 0x0 (NULL)
[SP+CC8] 0x22F7FFF8680 (void*)
[SP+CD0] 0x7FF798187D15 (SkyrimSE.exe+EE7D15) (void*)
[SP+CD8] 0xFC39609BA29 (u64):[17332710259241]
[SP+CE0] 0x22F5747CBD0 (void*)
[SP+CE8] 0x22F8050D168 (void*)
[SP+CF0] 0x8D8278F150 (void*)
[SP+CF8] 0x7FF798A55FE8 (SkyrimSE.exe+17B5FE8) (void*)
[SP+D00] 0x22F80517CB0 (void*)
[SP+D08] 0x0 (NULL)
[SP+D10] 0x7FF79818E376 (SkyrimSE.exe+EEE376) (char*) "H?\$pH??$?"
[SP+D18] 0x22F80564168 (void*)
[SP+D20] 0x8D8278EE29 (void*)
[SP+D28] 0x8D8278EDB0 (void*)
[SP+D30] 0x3 (u8):[3]
[SP+D38] 0x8D8278F118 (void*)
[SP+D40] 0x8D8278ED80 (void*)
[SP+D48] 0x0 (NULL)
[SP+D50] 0x7FF798185514 (SkyrimSE.exe+EE5514) (void*)
[SP+D58] 0x22F8006B280 (void*)
[SP+D60] 0x8D8278EDA8 (void*)
[SP+D68] 0x8D8278F118 (void*)
[SP+D70] 0x7FF7981807C7 (SkyrimSE.exe+EE07C7) (void*)
[SP+D78] 0x0 (NULL)
[SP+D80] 0x7FF79818C2E8 (SkyrimSE.exe+EEC2E8) (void*)
[SP+D88] 0x0 (NULL)
[SP+D90] 0x8D8278EE90 (void*)
[SP+D98] 0x22F7FF08EB0 (void*)
[SP+DA0] 0x7FF798181284 (SkyrimSE.exe+EE1284) (void*)
[SP+DA8] 0x7FF798A55FE8 (SkyrimSE.exe+17B5FE8) (void*)
[SP+DB0] 0x8D8278EE30 (void*)
[SP+DB8] 0x0 (NULL)
[SP+DC0] 0x0 (NULL)
[SP+DC8] 0x0 (NULL)
[SP+DD0] 0x7FF798185E00 (SkyrimSE.exe+EE5E00) (void*)
[SP+DD8] 0x22F8050D168 (void*)
[SP+DE0] 0x2800000003 (u64):[171798691843]
[SP+DE8] 0x22F8051D9C0 (void*)
[SP+DF0] 0x22F8006B2C0 (void*)
[SP+DF8] 0x7 (u8):[7]
[SP+E00] 0x7FF798189B43 (SkyrimSE.exe+EE9B43) (void*)
[SP+E08] 0x22F804F1740 (void*)
[SP+E10] 0x7FF79825971A (SkyrimSE.exe+FB971A) (void*)
[SP+E18] 0x8 (u8):[8]
[SP+E20] 0x22F801813B0 (char**) "available"
[SP+E28] 0x22F8050D100 (void*)
[SP+E30] 0x22F80517CD0 (void*)
[SP+E38] 0x8D8278F118 (void*)
[SP+E40] 0x8D8278F190 (void*)
[SP+E48] 0x7FF798A55FE8 (SkyrimSE.exe+17B5FE8) (void*)
[SP+E50] 0x22F5747CBD0 (void*)
[SP+E58] 0x0 (NULL)
[SP+E60] 0x22F80564168 (void*)
[SP+E68] 0x8D8278F150 (void*)
[SP+E70] 0x22F80517CD0 (void*)
[SP+E78] 0x8D8278F000 (void*)
[SP+E80] 0x7FF79818E376 (SkyrimSE.exe+EEE376) (char*) "H?\$pH??$?"
[SP+E88] 0x0 (NULL)
[SP+E90] 0x0 (NULL)
[SP+E98] 0x22F7FEF9540 (void*)
[SP+EA0] 0x22F804F7540 (void*)
[SP+EA8] 0x22F8050D168 (void*)
[SP+EB0] 0x8D8278F150 (void*)
[SP+EB8] 0x22F8006B2C0 (void*)
[SP+EC0] 0x7FF798182CDF (SkyrimSE.exe+EE2CDF) (void*)
[SP+EC8] 0x0 (NULL)
[SP+ED0] 0x0 (NULL)
[SP+ED8] 0x7FF798A55F00 (SkyrimSE.exe+17B5F00) (void*)
[SP+EE0] 0x22F5747CBD0 (void*)
[SP+EE8] 0x0 (NULL)
[SP+EF0] 0x7FF79819BA1A (SkyrimSE.exe+EFBA1A) (void*)
[SP+EF8] 0x8D8278F150 (void*)
[SP+F00] 0x22F8050D168 (void*)
[SP+F08] 0x22F8050D168 (void*)
[SP+F10] 0x22F80564168 (void*)
[SP+F18] 0x2 (u8):[2]
[SP+F20] 0x22 (u8):[34]
[SP+F28] 0x1 (u8):[1]
[SP+F30] 0x180 (u16):[384]
[SP+F38] 0x22F7FA80801 (void*)
[SP+F40] 0x8D8278F1B0 (void*)
[SP+F48] 0x22F8006B2C0 (void*)
[SP+F50] 0x22F8050D168 (void*)
[SP+F58] 0x22F00000002 (void*)
[SP+F60] 0x22F00000002 (void*)
[SP+F68] 0x22F80517CD0 (void*)
[SP+F70] 0x7FF700000000 (u64):[140698833649664]
[SP+F78] 0x0 (NULL)
[SP+F80] 0xF (u8):[15]
[SP+F88] 0x22F8050CF00 (void*)
[SP+F90] 0x100000C (u32):[16777228]
[SP+F98] 0x22F8050D168 (void*)
[SP+FA0] 0x22F8050D000 (void*)
[SP+FA8] 0x22F804C23C0 (void*)
[SP+FB0] 0x0 (NULL)
[SP+FB8] 0x2ED0000030D (u64):[3216930505485]
[SP+FC0] 0x7FF7000002EC (u64):[140698833650412]
[SP+FC8] 0x22F803B9CC0 (void*)
[SP+FD0] 0x22F58B672E0 (void*)
[SP+FD8] 0x7FF798A5C450 (SkyrimSE.exe+17BC450) (void*)
[SP+FE0] 0x22ED04E5FD0 (anonymous_namespace::LoggingDisabler*)
[SP+FE8] 0x8D82000100 (u64):[607771427072]
[SP+FF0] 0x0 (NULL)
[SP+FF8] 0x5020F (u32):[328207]
Modules
SkyrimSE.exe: 0x7FF7972A0000
ntdll.dll: 0x7FFC287A0000
KERNEL32.DLL: 0x7FFC267D0000
KERNELBASE.dll: 0x7FFC26280000
bdhkm64.dll: 0x7FFC09BA0000
atcuf64.dll: 0x7FFC09A50000
apphelp.dll: 0x7FFC22E70000
USER32.dll: 0x7FFC284B0000
win32u.dll: 0x7FFC26250000
GDI32.dll: 0x7FFC27D30000
gdi32full.dll: 0x7FFC25C50000
msvcp_win.dll: 0x7FFC25D70000
ucrtbase.dll: 0x7FFC26130000
ADVAPI32.dll: 0x7FFC27670000
msvcrt.dll: 0x7FFC27280000
sechost.dll: 0x7FFC27720000
RPCRT4.dll: 0x7FFC28350000
SHELL32.dll: 0x7FFC26AB0000
ole32.dll: 0x7FFC274D0000
combase.dll: 0x7FFC27DE0000
WS2_32.dll: 0x7FFC27450000
SETUPAPI.dll: 0x7FFC277C0000
OLEAUT32.dll: 0x7FFC28270000
X3DAudio1_7.dll: 0x61160000
XINPUT1_3.dll: 0x400000
DINPUT8.dll: 0x7FFC03270000
binkw64.dll: 0x180000000
WINHTTP.dll: 0x7FFC1EE90000
IPHLPAPI.DLL: 0x7FFC248E0000
steam_api64.dll: 0x61050000
MSVCP140.dll: 0x7FFC0DF60000
WSOCK32.dll: 0x7FFC222C0000
VCRUNTIME140.dll: 0x7FFC0E100000
d3dx9_42.dll: 0x7FFC13520000
SHLWAPI.dll: 0x7FFC28160000
d3d11.dll: 0x7FFC207C0000
HID.DLL: 0x7FFC245B0000
WINMM.dll: 0x7FFC1F370000
dxgi.dll: 0x7FFC230D0000
VCRUNTIME140_1.dll: 0x7FFC0DFF0000
IMM32.DLL: 0x7FFC28230000
skse64_steam_loader.dll: 0x7FFC070B0000
VERSION.dll: 0x7FFC1DE60000
inputhost.dll: 0x7FFBFE0D0000
CoreMessaging.dll: 0x7FFC22B80000
windows.storage.dll: 0x7FFC23D40000
wintypes.dll: 0x7FFC23BD0000
SHCORE.dll: 0x7FFC266C0000
bcryptPrimitives.dll: 0x7FFC26040000
profapi.dll: 0x7FFC25B80000
CRYPTBASE.DLL: 0x7FFC254D0000
usvfs_x64.dll: 0x7FFB95200000
steamclient64.dll: 0x7FFB82900000
CRYPT32.dll: 0x7FFC25ED0000
imagehlp.dll: 0x7FFC28480000
PSAPI.DLL: 0x7FFC28750000
tier0_s64.dll: 0x7FFB96730000
vstdlib_s64.dll: 0x7FFB976F0000
MSWSOCK.dll: 0x7FFC25260000
bcrypt.dll: 0x7FFC25630000
Secur32.dll: 0x7FFC1CFF0000
SSPICLI.DLL: 0x7FFC25050000
NetScriptFramework.Runtime.dll: 0x7FFC071F0000
dbghelp.dll: 0x7FFC237F0000
mscoree.dll: 0x7FFC0DD50000
dbgcore.DLL: 0x7FFC09760000
mscoreei.dll: 0x7FFC0DAD0000
kernel.appcore.dll: 0x7FFC24DC0000
clr.dll: 0x7FFC0AF80000
VCRUNTIME140_CLR0400.dll: 0x7FFC0ABE0000
ucrtbase_clr0400.dll: 0x7FFC0AB20000
mscorlib.ni.dll: 0x7FFC07C60000
clrjit.dll: 0x7FFC06B60000
wldp.dll: 0x7FFC25580000
amsi.dll: 0x7FFC19D30000
USERENV.dll: 0x7FFC25360000
antimalware_provider64.dll: 0x7FFBF9110000
System.ni.dll: 0x7FFC05AF0000
System.Core.ni.dll: 0x7FFC03470000
urlmon.dll: 0x7FFC1F870000
iertutil.dll: 0x7FFC1F0B0000
srvcli.dll: 0x7FFC1F3B0000
netutils.dll: 0x7FFC24860000
PROPSYS.dll: 0x7FFC218D0000
virtdisk.dll: 0x7FFBF58E0000
FLTLIB.DLL: 0x7FFC18FB0000
NetScriptFramework.SkyrimSE.dll: 0x7FFB96610000
EngineFixes.dll: 0x7FFB96510000
tbb.dll: 0x7FFB964A0000
tbbmalloc.dll: 0x7FFB96430000
skse64_1_5_97.dll: 0x7FFB94D90000
EnderalSE.dll: 0x7FFB96370000
fs_steam.dll: 0x22E99800000
JContainers64.dll: 0x7FFB92260000
SkyrimRedirector.dll: 0x7FFC024B0000
SSEDisplayTweaks.dll: 0x7FFB92170000
YesImSure.dll: 0x7FFB945A0000
uxtheme.dll: 0x7FFC22F60000
gameoverlayrenderer64.dll: 0x7FFB91FE0000
MSCTF.dll: 0x7FFC27330000
textinputframework.dll: 0x7FFBFD680000
CoreUIComponents.dll: 0x7FFC20C30000
dxcore.dll: 0x7FFC23210000
directxdatabasehelper.dll: 0x7FFC216E0000
ntmarta.dll: 0x7FFC24DE0000
nvldumdx.dll: 0x7FFC1DC10000
msasn1.dll: 0x7FFC25510000
cryptnet.dll: 0x7FFC1E8B0000
drvstore.dll: 0x7FFC1DA20000
devobj.dll: 0x7FFC25920000
cfgmgr32.dll: 0x7FFC25960000
WINTRUST.DLL: 0x22E9C300000
CRYPTSP.dll: 0x7FFC254B0000
rsaenh.dll: 0x7FFC24D20000
nvwgf2umx.dll: 0x7FFC141E0000
dcomp.dll: 0x7FFC21180000
dwmapi.dll: 0x7FFC23390000
XAudio2_7.dll: 0x7FFB91F50000
clbcatq.dll: 0x7FFC26610000
MMDevApi.dll: 0x7FFC1BB90000
resourcepolicyclient.dll: 0x7FFC23290000
AUDIOSES.DLL: 0x7FFC13D90000
powrprof.dll: 0x22ED0850000
UMPDC.dll: 0x7FFC246B0000
Windows.UI.dll: 0x7FFC03020000
avrt.dll: 0x7FFC21610000
DSOUND.DLL: 0x7FFC0E050000
ResampleDmo.DLL: 0x7FFC0DC90000
winmmbase.dll: 0x7FFC10720000
msdmo.dll: 0x7FFC0DC80000
wbemprox.dll: 0x7FFC1C8E0000
wbemcomn.dll: 0x7FFC1B710000
wbemsvc.dll: 0x7FFC1A780000
fastprox.dll: 0x7FFC1AAD0000
NSI.dll: 0x7FFC27D20000
dhcpcsvc6.DLL: 0x7FFC1EE70000
dhcpcsvc.DLL: 0x7FFC1F7E0000
DNSAPI.dll: 0x7FFC24910000
webio.dll: 0x7FFC0AD00000
WINNSI.DLL: 0x7FFC1F710000
rasadhlp.dll: 0x7FFC19BC0000
fwpuclnt.dll: 0x7FFC1DB80000
schannel.DLL: 0x7FFC24C20000
mskeyprotect.dll: 0x7FFC00030000
NTASN1.dll: 0x7FFC255C0000
ncrypt.dll: 0x7FFC25600000
ncryptsslp.dll: 0x7FFC002B0000
DPAPI.DLL: 0x7FFC25950000
Plugins (0)
Game plugins (7)
[00] Skyrim.esm
[01] Dawnguard.esm
[02] HearthFires.esm
[03] Dragonborn.esm
[04] Update.esm
[05] Enderal - Forgotten Stories.esm
[06] SkyUI_SE.esp
Kermit 61
Schöpfer
Schöpfer
Hat sich bedankt: 398 Mal
Danksagung erhalten: 519 Mal
Hello Jojash!
The (rare!) problem with the wrong location of Enderal SE saves is known. A clear cause (such as possibly Skyrim Redirector) or a solution we do not currently know :-(
In a pinch, you can also play that way.
On the subject of mods/crashes:
I assume after you had problems with Vortex (I don't know of any because of Enderal SE, I also used Vortex myself) you installed mods manually? I assume you know how that works ;-)
If so which mods?
Does a mod possibly cause crashes? There is an NPC Tharael in the game but there are also no errors known to me.
Otherwise you still have the possibility to ask on the Enderal SE Discord.
Enderal SE was not developed by SureAI but as a fan project of Eddoursul.
Jojash
Grünschnabel
Grünschnabel
13.05.2023 12:22Kermit 61 hat geschrieben:
Hello Jojash!
If so which mods?
Ahhhh! My mistake, I had thought that Enderal was developed by SureAI! I'll give the Discord a go as well, thank you for pointing it out!
Actually, I switched over to using MO2 as I'd heard it had good compatibility with Enderal. After doing manual installs with FO3 and NV back in the day, I'm keen to avoid it now that I have the option! :lol:
The weird thing is that any mod causes the crashes. My focus was originally on Nemesis/TDM/Smoothcam/MCO, but after doing clean installs etc, running a completely vanilla save with only the .NET Framework mod I've linked installed still crashes when trying to save. It's truly bizarre. I have made sure it's not just that mod as well, Nemesis, TDM, etc all cause crashes individually as well which is why I'm convinced it's something to do with a file packed with Enderal pointing in the wrong direction or something, with the shared save location being symptomatic.
I'm also not convinced the NPC I've listed is the problem, just thought it was worth pointing out since .NET mentions them - I can't imagine a scenario where you'd need an invisible NPC for scripting purposes or why you'd name that NPC though, but Beth games are weird and the workarounds used for them notorious, so I'm not ruling it out either. I should mention that I'm barely past character creation, so I've not met anyone named Tharael either, if the NPC I'm listing is in the game, I suspect they're not used to interact with the player in a traditional sense, or perhaps their name is a token for something else?
Kermit 61
Schöpfer
Schöpfer
Enderal is from SureAI. There are 2 versions but the content is identical. The Enderal classic (based on the old Skyrim engine) and the Enderal Special Edition (based on the more modern engine of the Skyrim Special Edition).
The Enderal Special Edition was adapted by Eddoursul to the more modern engine (SureAI has provided technical support, for example, regarding the Steam connection).
About Tharael: he will be a very important NPC in a big quest series later (he appears much later when triggered. But no spoilers ;-) ) ;-)
But I don't see any connection with your problem.
I also still don't think that your save location problem is a cause for the crashes. In any case, I am not aware that others who had this problem also had crashes.
I suspect your problem is caused by incompatible Skyrim mods (though I don't know the ones you mentioned). I recommend only using mods written for or adapted to Enderal SE. Look here.
Yes there are compatible Skyrim mods too. These must then be tested in each individual case.
Otherwise here is the link to the SureAI Discord. There you will also find channels about Enderal SE and modding.
