6 posts • Page 1 of 1
Good morning,
I would like to thank you for this great adventure that you offer us, more emotions and adventure, thank you.
Unfortunately for some time my adventure is marred by several problems of missing textures.
I have the latest version of the game and I use enb.
the first time I observed this phenomenon on the way to the gate of Bleakstar castle
Here I am in Thalgard and I can't move forward because the ground texture is missing... what a frustration! Here is the screenshot:
*i use console then "tcl" command to arrive on the bridge
Same thing for the first cave when we go to get the stones to take the airship in the last chapter.
Are these problems identified, is a patch on the way to correct this?
Thanks for all the feedback you can give!
hi, welcome to the forum!
first things first - that's not an Enderal bug.
was your ENB made for Enderal? if not, it's the likely culprit.
you could look through the options and try to find the offending one
(enabled AntiAliasing caused a missing floor right in the beginning of the game, so it might be that?).
(can't help you much besides that, i don't use ENBs :/ )
otherwise it might be one of your other mods.
SMIM (Static Mesh Improvement Mod) for example did cause an issue like that without a patch for Enderal.
any Skyrim mod without a patch can (and probably will) be a problem, maybe excluding UI mods.
you might need to deactivate (or better uninstall) all of your mods to find the one that causes the missing ground.
we can help you narrow it down if you give us a list :)
good luck!
I have indeed mods on my game but not the SMIM because I know that it generates texture problems
I'll do some tests and bring you back the one that messes up
if it can help some people
i find the mod for castle bleakstar: Morning Fogs SSE
Next step: Thalgard road...
113 mods and it was just the mod "morning fogs" that generated the missing textures
d'ailleurs voici ma liste, je n'ai rencontré aucuns autres bugs bloquant avec, pour celles et ceux qui voudrait les installer ;)
#Mod_Name
"Unmanaged: forge_light_starship"
"Address Library for SKSE Plugins"
".NET Script Framework"
"XP32 Maximum Skeleton Special Extended"
"powerofthree's Tweaks"
"Base Object Swapper"
"Complete Widescreen Fix for Vanilla and SkyUI 2.2 and 5.2 SE"
"ENB Helper SE"
"Nocturnal Moths"
"ENB Light"
"ENB Lights For Effect Shaders"
"Diverse Weather"
"Bears of the North"
"Enderal SE - Bears of the North"
"Enderal Armor and Weapon Overhaul"
"The Notice Board Redefined for Enderal"
"Cannons 2K"
"Enderal Upscale Project (2K version)"
"Enderal SE - Seagulls of Skyrim"
"Enderal SE - Flying Crows"
"ENB Loading Screen Fix"
"Enderal SE - Dwemer Automatons Glowmapped"
"Emissive Glow Plane Fix for ENB"
"No more Skyrim-looking Creatures (now including lost ones)"
"Amanda - Enderal SE Follower"
"ENB Main Menu Fix"
"Boneripper Replacer (Clannfear Variant)"
"R.A.S.S. - Rain Ash And Snow Shaders"
"EAWO"
"Auto Input Switch"
"Dynamic Volumetric Lighting and Sun Shadows"
"Enhanced Blood Textures"
"JS Lockpicking UI SE"
"Majestic Mountains"
"Metallurgy - Ingots Ore and Veins HD"
"Mr. Dragonfly ENB Particle Light"
"No Spinning Death Animation"
"Obsidian Mountain Fogs"
"Oxygen Meter 2"
"Real Fur for Wolves"
"Realistic Water Two SE"
"Smoking Torches and Candles SSE"
"Soaking Wet - Character Wetness Effect"
"Torches Cast Shadows SE"
"Goetia Animations - Female Idle Walk And Run"
"Enderal SE - Dynamic Fast Travel"
"Emporium Fix"
"ALDER Arcane Fever Remove And night vision"
"A Matter of Time - A HUD clock widget"
"HDT-SMP (Skinned Mesh Physics)"
"Artesian Cloaks of Skyrim"
"Bent Pines II"
"Cloaks and Capes"
"Dynamic Animation Replacer"
"Faster Bows"
"Gesture Animation Remix (DAR)"
"GOAT HD by Pfuscher"
"JContainers SE"
"iEquip"
"Immersive HUD - iHUD Special Edition"
"Enderal SE - Bug Fixes"
"Improved Weapon Impact EFFECTS Correct Metal SE"
"NPC Animation Remix (DAR)"
"nuages_realistes_"
"Simplicity of Snow"
"Particle Lights For ENB SE - Bugs in a Jar"
"Rock Grass for ENB Complex Grass SE (with Guide)"
"Xenius Character Enhancement Complete"
"Vanilla hair - Salt and Wind"
"Salt and Wind - KS Hairdos - Update"
"KS Hairdos SSE"
"Water Effects Brightness and Reflection Fix"
"Water Mod"
"Blended Roads"
"Mushrooms - High Poly - Old"
"Particle Patch for ENB"
"Static Cobbles - Mid Poly"
"High Poly Head SE"
"Expressive Facegen Morphs SE"
"Expressive Facial Animation -Female Edition-"
"Expressive Facial Animation -Male Edition-"
"NPC Pathing Fixes (Suncoast)"
"NPC Pathing Fixes (Heartland)"
"NPC Pathing Fixes (Whisperwood)"
"Old Tunnel Pathing Fix"
"Undercity Arena Fix"
"Enderal Texture Workshop"
"DK's Enderal NPCs"
"Enderal SE - Conditional Expressions"
"Assorted mesh fixes"
"Unofficial Material Fix"
"EVG Conditional Idles"
"EVG Animation Variance"
"Simple Dual Sheath"
"Darker Tree LOD for Enderal - Version 2.0.7"
"Oblivion Horses SE Basic Version. For manual installation"
"Enderal SE - Immersive Interactions"
"FAA - Fixes And Adjustments"
"KS Hairdos Patch"
"Cathedral - Mushrooms"
"Weather Fixes (R.A.S.S. and Storm Lightning compatibility)"
"Dragon Replacer"
"Ancestral Spirit Replacer (4 Variants)"
"Pus Beetle Replacer"
"Enderal Donkey (Whirlwind and Dagaric)"
"EGO SE - Donkey"
"Experimental Model and Textures for V 3.0"
"Skyland - Imperial Forts and Dungeons"
"Facelight Plus SE"
"Ultimate HD Fire Effects"
"Golden Dwemer Pipeworks Redone 4K - 2K"
"TB's 8K Immersive Mines"
"Ambiance - A Vanilla+ Ambient Lighting Overhaul"
"Enhanced Lights and FX"
hey, glad to know you could find the issue!
thank you for the heads up :D
