3 posts • Page 1 of 1
"Angel" quest bug?
Post by deadlineboy »
08.05.2020 11:06Stefanie wrote:
then give us your current Save and we'll see whether it can be salvaged
Hi, Stefanie
Can you please assist me too? I'm also stuck on the quest Angel. first, I can't find the key for the right tower, so i used console command to add item. after that, the scene in the crystal room does not start. I attached my save files, list of quests, and list of mods I'm currently using. Any help would be appreciated. Thanks!
ENDERAL Request Bug .rar
(2.75 MiB) Downloaded 183 times
Re: "Angel" quest bug?
Post by Stefanie »
Hello deadlineboy
first a hint, cheats can permanently damage the game, at least in the wrong place or at the wrong time!
We usually can't repair such bugs.
If any game problems occur, better always ask us before using a console!
About your score:
You probably shot the key and other items in the last fight.
If you turn around now and go back downstairs, you will see a railing through the door you cracked.
(With a stone table right behind it in the room with all the undead).
Now if you stand so that the big round table is directly behind your back, there is said railing in front of you,
next to the stone table on the bottom righthand side of the floor is a sheet of paper and under it just the key you're looking for.
(yes, a pretty lousy coincidence).
Take this key and everything goes on as planned^.
oops, my bad....
sorry, wasn't aware that the key is the scene trigger.
yes, I passed the quest now. Thank you so much for the help, and kudos to you and all of the team for the enjoyable game! :)
