Started a new game and I get to the part where Finn comes over to talk to you, he gets through his lines, Carbos comes down to talk to him and sees you. Carbos gives his lines then everyone stares at each other and nothing happens after that. The game is not frozen, all the in game menus are still accessible but nothing happens after that.
Welcome to the forum
Do you use any mods or have you ever used cheats?
Please send us a savegame. Then we are able to see if we can reproduce the problem.
You can find them (depending on your Enderal FS version) in
...\Documents\My Games\Enderal\Saves or
...\Documents\My Games\Enderal Special Edition\Saves
We'll need the *.ess and the *.skse file.
Best a manual save (no auto or quicksave).
Pack both to a zip or rar archive (the forum doesn't accept *.skse format).
Thank you very much for your quick response. I have used TCL and TGM once before.
I do have some mods installed. At one point this was all working months ago then it just stopped for no apparent reason, hence my new game I am starting. Almost all my mods are texture mods however. I forgot to mention that is for Enderal SE which I installed through Steam.
Desktop.zip
(850.81 KiB) Downloaded 145 times
I think I may have figured it out. I was using the mod:
https://www.nexusmods.com/enderalspecialedition/mods/2
And that looks like for whatever reason that it was causing the bug which is ironic ¯\_(ツ)_/¯
Your save works for us without any problems.
Mods are of course always the first suspects...
Enhanced Blood was my first suspicion (it changes not only textures but also scripts). Bug fixes rather not...
But I would also remove it to be on the safe side.
But it's very good that it works again for you
And I recommend to make manual saves more often in the future in case a problem should occur again.
Thank you for the quick support! You guys are awesome!
