Special Edition version - Quest THE VOID - stage: Accompany Jespar to Ark (5 out of 6 shown stages complete) ----- Entered Ark for the first time, Jespar began a bit of dialogue once the city loaded - but Jespar turned around and opened the door to leave Ark during the dialogue. No where to be found now - not inside or outside the gates, not in or out of the Dancing Nomad - even using console command to force Jespar to the players location does nothing. The Quest Marker for this is set on the ground at the entrance I first walked in from.
when i click bugtacker link it just redirects me to homepage so idk what all that is, sorry if this is not the right place.
Hello omverse
The console can cause errors that can't be repaired afterwards. Therefore, fingers away from it.
Can you send us a save before you made any attempts with the console?
(preferably also a 2nd save before entering Ark)
saved games can be found here:
We need the -.ess and the -.skse file of the same name, put both in a zip or rar archive (the forum does not accept *.skse otherwise).
If possible no autosaves or quicksaves, but a manually saved game.
The old bugtracker is closed, because there will be no more patches for the 32bit version.
Tip: save a lot, not only with quick- or autosave, but with many fixed savegames.
Code Select all
...\Documents\my games\Enderal Special Edition\SavesIf possible no autosaves or quicksaves, but a manually saved game.
Thank you for the quick response, Stephanie -
I will send those files, but the save will be - uhm - before leaving the Abandoned Temple - is that alright?
it will be the only one before using any console commands, ive since deleted all the others.
otherwise, i dont mind making my way back - and if it repeats, send the files before and after, etc
also - simple question but where will I send the files? -- to support@sureai.net ?
hi,
if you write a post here in the forum there's a tab "attachements", you can use that
Couldn't get it to repeat this time --
Most I could say about it is that I did a bit of exploring before walking with Jespar to Ark
completed A Nice Day in Summer, A New Life, It Starts with Dreams, A New Beginning, Feud Between Brothers, Bad Vibrations, Secrets from the Can
-- all before walking to Ark with Jespar
and explored areas from Three River Cabin, to Ore Terminal, to ClearWater Cave
Ill see if I can get it to happen again, but otherwise, I have a file without the bug so thank you!
