Hello, guys!
I'm literally stuck at the main quest and I see no solution out there. I've already asked in Discord, searched all the wikia and forums in English and German both.
Here's the deal: I was doing the bounty hunter questline, get "The Juggler" quest, killed my target and looted his corpse. Some time passed, and I noticed that I wear The Juggler's hat, hood or whatever it is and, what's the most important, I CAN'T REMOVE NOR UNEQUIP IT.
I ask you for help, guys. I can't use the diving helmet because it requires exactly a helmet slot, so I can't continue the main quest. I don't wanna drop the game cause the story and etc makes me turn a blind eye to bugs and FPS. Especially I don't wanna drop the game at the finish line.
Please, help me. I've added the save files.
(I don't want my char to look like a Dungeon Master, really hope it's not forever
Saves.rar
(3.31 MiB) Downloaded 694 times
Hi Wolfand!
We can take off the hat as normal
Are you using any mods that could be causing the problem for you?
Just to be on the safe side, I'll send you a manuel save without the hat
Wolfand.rar
(1.64 MiB) Downloaded 620 times
22.04.2021 17:30Kermit 61 wrote: Hi Wolfand!
We can take off the hat as normal![]()
Just to be on the safe side, I'll send you a manuel save without the hat![]()
Thank you very much for the help, gonna try the save files ASAP.
I see that my problem is surprising, right? May I record a video for you to see what's exactly happening in my game? I don't have any mods or etc. I just use oficially offered translation to my language.
23.04.2021 13:46Wolfand wrote: I play in Russian.
It is obviously a bug that occurs in the Russian version.
I can't answer you at the moment if and when the bug will be fixed.
Can you keep playing with my save?
As you told me on Discord my save works for you. So solved!
