5 posts • Page 1 of 1
Deleted User 27017
The Heart of the Swashbuckler is bugged
Post by Deleted User 27017 »
The Heart of the Swashbuckler uses the Old Vagrant Dress model, despite showing the correct one when you drop it. Latest update.
Welcome to the forum and thank you for your message :) !
Unfortunately there will be no more patches for Enderal Forgotten Stories. The final patch was 1.6.4.0 (please see the explanation there)
Sorry! I hope you still have a lot of fun with Enderal FS!
Deleted User 27017
Re: The Heart of the Swashbuckler is bugged
Ok. Any ideas on how to fix it though?
hi,
i'll try to explain as well as i can (hoping we understood you correctly).
- if you don't have the correct mesh and know the correct folder you need to get the CK and the BAE working for Enderal
here's a description on how to do that
(- because I couldn't get it to work the screenshot below is using Skyrim)
- there was probably a good reason the mesh was changed. maybe it was buggy, maybe it was badly optimized, just so you know.
there are two ways to go about that - replacing the mesh directly or creating an esp.
in both cases you need the same tools
this is a link to the armor in question in the wiki.
the IDs might help you, but be wary of spoilers.
assuming you opened Enderal with the CK
1 - look the Armors up. (the "Heart of the Swashbuckler" and an armor that uses that cuirass (no idea what it's called, sorry)
but possibly \meshes\Enderal\armor\Ranger\rangercuirass_0.nif OR \rangercuirass_1.nif )
2 - in this pic it's a bandit cuirass
3* - the name with GO at the end is the groundmodel. if you click "edit" next to that you'll see the filename and folder (as a hint on where to look for your files).
3 - this is the place you want to double click
4 - this is the model that changed, so you click that. there's a male and a female section.
4*- this mesh is used in 1st person. (if no other is available it's usually the "normal" armor)
5 - click on edit transports you to "meshes" - folder
open (at any point) BAE and try to find the cuirass you're looking for. export it into the Swashbuckler folder.
now either rename Cuirass to the name the Swashbuckler uses or change it with the CK.
in that case, at the end ok everything and save the esp.
good luck, hope that helps :)
Deleted User 27017
07.02.2021 20:05urst wrote:
hi,
Thanks a lot for such a thorough explanation. I think that does it.
