The sounds of water and npc objects started act strangely, I think they're bugged.
I have some modifications downloaded, there are not very many of them and I have already encountered some problems related to them, but I seem to have solved them, at this moment I do not know what the problem is. Elevators in the game are sometimes not considered as physical objects and simply do not lift the character.
67 - Arsi 138.41.12.skse.7z
(3.09 KiB) Downloaded 114 times
quicksave.7z
(3.03 KiB) Downloaded 110 times
Desktop Screenshot 2021.02.02 - 23.03.37.30 (2).png (8.76 KiB) Viewed 1297 times
hi, welcome to the forum!
FPS higher than 60 cause this. (both the sound and the mesh issues)
ENBoost includes a limiter (if you didn't alter the ini file), so if you do not use an ENB
and ENBoost doesn't cause issues on your system I'd advise you to activate it (otherwise there should be a setting in your ENB)
if you want to use neither you might need a third party tool for yor graphics card or a mod like the fps limiter
(i have NO idea if and how this mod works with Enderal.)
hope that helps
hope that helps
Thank you so much, it seemed to help
