hello there,
I was doing the quest with Naratzhul to retrieve the blade and there was a part where you had to cross some brigdes real quick before they went up again. To do this you got a temporary boost to your speed. Im several hours further now and still have the speed boost. It was fun at first, but now my character is so fast its not even immersive anymore.
hi
could you upload a save please?
was something on that sequence out of the ordinary? (aside from the buff that should only hold on for a few seconds)
here ya go
Save 2303 - Vorhert the Spicy lad - The Southern Peninsula (Level 30 to 35), Level 27, Playing Time 32.10.30.ess
(4.45 MiB) Downloaded 148 times
Save 2306 - Vorhert the Spicy lad - Ostian, Level 27, Playing Time 32.14.22.ess
(4.47 MiB) Downloaded 133 times
ok, we can't remove the actual buff, because it isn't there anymore, only the atrribute/skill increase.
don't know how that happened.
but this solution should solve it, hopefully without repercussions.
the console commands you need are
this removes the bonus, it won't touch the actual level.
Code Select all
player.modav speed -100
player.modav athletics -100
