Hello!
I'm just trying to disable the compass from the hud. I would be nice to know if this is possible.
I've looked around trying to find an option to turn off the compass, unfortunately it seems it not simple as in skyrim where you can just edit the .ini files.
I know DarnUI has this functionality. Is there any way to get DarnUI to play well with Nehrim? It looks to mostly work but the inventory font is very, very bold and does not fit properly and I am unsure if it will cause problems later down the line.
I would be thankful for any input.
Thanks!
Thanks!
I think I fixed the fonts. I will explain how below
All I had to do is copy the entire [Fonts] section after installing DarnUI from oblivion.ini in Documents\My Games\Oblivion and replace the [Fonts] in Oblivion.ini located in the games main file directory. (In my case Program Files (x86)\Steam\steamapps\common\Oblivion)
I am using the steam version of Oblivion and Nehrim so it may differ if you are not.
I am still uncertain if this breaks anything in the game later on.
