5 posts • Page 1 of 1
This suddenly happened after I leveled up, went into memory world and came back.
I tried loading a previous save that I was sure worked, but it still persisted. Any ideas?
Edit: No idea how to add in a picture preview, so
https://imgur.com/a/xVp701M
hi, welcome to the forum :)
do you have any mods installed?
did you try to meditate again and see if that changes anything?
restarting the game might also help.
(to be honest, I don't remember seeing that issue before)
could you please attach a savegame (no auto- or quicksave)?
or multiple, one before that happened and a current one.
they're found in (...\Documents\My Games\Enderal). we'll need the *.ess and the *.skse file;
pack both to a zip/rar/whatever archive, the forum doesn't accept *.skse.
thank you :)
thank you :)
Hey! Thanks for the response. I have narrowed down my issue, as seen in my reddit post here:
https://www.reddit.com/r/enderal/commen ... hing_more/
It seems that my sky is stuck as the memory world's (can't remember what its called..) sky .
I have multiple mods, but I think the one that is affecting it is S-ENB.
Validating files would always say 2 files failed (enblocal.ini and enbseries.ini), and upon resetting them the issue is gone.
At the moment, I have managed to sieve through the differences between the default ini files and the ones provided by S-ENB, and managed to have all the settings from S-ENB transferred into the default ini.
Now the issue is partially fixed. My reddit post will show you what I mean by 'partially'.
I have attached the most recent save file. I don't think I have a save file before it happened (Since they all got 'corrupted' by the sky anyway).
Saves.rar
(1.7 MiB) Downloaded 91 times
The bug's been fixed. I just did a set timescale for it to change to day and it fixed itself! :lol:
hi :)
thank you!
the issue was still visible in the save but solved itself when meditating again,
so the effect is at least not completely stuck.
are you using the Enderal version of the ENB?
if so, I'd suggest you'd contact the mod author and let them know about this bug.
