I play at Enderal forgotten Stories , i want to know if it's possible to make an object or a decoration in my house ?
I've bought the noble house and i can't do anything, if i try to take a decoration in my inventory, i can't place it , why ?
Thanks !
Thanks !
You have the option to customize the two houses of your own or to buy a preset.
Furniture to set up in your own house can be made according to construction plans (mostly found at some dealers in Ark).
Quick guide, set up your own furniture in your own house:
- drop from inventory = press the Key R
- positioning the furniture with navigation keys (A;W;S;D)
- then hold E for ~3 seconds for the next option
- now you can adjust the furniture (Height or rotation with navigation keys)
- to leave the construction menu = hold E 3seconds
-or press E shortly to pick up the object again
-hold E again for 3 seconds for later pick-up
Press the E key shortly to interact with this objects
if no placement is possible, there may not enough space to storage, choose a place with enough free space
OK Thanks,
But, when i press e 3s, i take the object in my inventory, i can't place it :/
In that case, please tell us what the item is and upload your savegame so we can test it.
(or maybe you are at the wrong menu-point for holding E?)
You found it in (...\Documents\My Games\Enderal), we'll need the -.ess and the -.skse-file. Pack both to a zip/rar/whatever archive
(the forum doesn't accept -.skse-file directly).
