Welcome to the forum
I have moved your thread to the support section.
Did you also deactivate the controller in the Launcher settings?
Possible solutions:
- Restart your PC and Enderal again.
Does that help?
- delete the Enderal.ini and the EnderalPrefs.ini (in C:\Users\...\Documents\My Games\Enderal). The Launcher will create new ones at the next start.
- check your game by Steam
Possible solutions:
Does that help?
sweet! deleting the enderal ini and prefs worked! weird, should of been just a standard ini file on start. i will say that i had the controller plugged in but not activated in the ini so maybe that screwed things up? im also able to play through mo2 now, just transfered the working ini's to mo2's profile. thanks again
Fine
There is a backup for the both standard ini files in the Enderal game folder. Named Enderal_default.ini and EnderalPrefs_default.ini.
