15 posts • Page 1 of 1
I play two-handed char and I use Fury-Driven perk (health regeneration while fighting with two-handed waepon). It worked perfectly. After some time I tried to restore my health by "fighting" some weak and slow opponent and I noticed I don't have any regeneration. Combat mode (music involved) doesn't start. So I was testing a bit and the combat mode turns on very rarely. For me about 1 in 5 fights. Enemy is always shown as red dot on the radar. It's weird because food doesn't restore my health in this half combat mode. So I searched posts and I found the music problem description - about not starting combat music. My level can be a problem (it's 50)? So the game doesn't start combat music against low level enemies but also doesn't start combat mode?
hi :)
could you please attach a savegame so we can take a look at that?
they're found in (...\Documents\My Games\Enderal).
we'll need the *.ess and the *.skse file; pack both to a zip/rar/whatever archive, the forum doesn't accept *.skse.
thank you :)
Here you go.
Saves.zip
(2.22 MiB) Downloaded 312 times
I am not sure if I understood everything correctly :dumb:
I tested your save.
Health regeneration perk works without problems. No matter whether with or without an opponent when using your two-handed weapon.
Combat music is supposed to be a warning. If you have an opponent who is well below your level (50!), it will not sound because it is not a challenge for you.
Food only works outside of combat mode.
So I think everything works correctly for you as intended.
https://ufile.io/ml86jtky
A short clip. Out of combat - no regeneration. In combat , still no regeneration. :/
In this video you are wearing a one hand weapon and a shield and no two hand weapon (for your perk)... :?:
So of course you have no regeneration.
The skill only works with two-handed weapons.
It's two-handed hammer.
https://ufile.io/g4zpn96e
I think no...
It is a one hand weapon which you can also use with both hands (for more damage). Otherwise you could not wear a shield.
Show the item description.
edit: otherwise please send us a new save with this weapon
https://ufile.io/5m7rcekw
Aeterna Warhammer
Okay save please :)
Here it is :)
Saves.zip
(2.34 MiB) Downloaded 136 times
We will discuss it with our Dev :wink:
Did you install the last update from Enderal (November 2019)? Since the perk was actually fixed ... :?
Did you ever have mods installed?
In what language do you play (English?)?
Also check your game with steam.
I installed the game on steam 6th january 2020. Earlier I was playing non steam version on completely different computer, so it's brand new version.
Never installed a single mod for Enderal.
Only English version.
Just checked files. It said that could't verify - downloading new files. So I started one more time - verified successfully.
Now it works like a charm :lol:
Thank you for help and sorry for the trouble :thumbsup:
Very good! We already feared a new bug ... :sick: :shock: :wink:
