I have a steam copy of classic skyrim (not installed). I just downloaded and installed Enderal from steam, then tried to lauch it and got the error "skyrim has stopped working".
I also tried every suggestion in this thread, buy nothing worked:
https://steamcommunity.com/app/933480/d ... 833347820/
When i validate the files through steam it found 3 files missing, then again 1 file missing when i tried the validation again after another failed lauch.
I attach the Launcher.log file
I'm running windows 7 x64 and i'm 100% sure i don't need to update some driver. I'm currently playing many games with this PC and never had such problems.
Any help, please?
Any help, please?
Launcher.log
(42.86 KiB) Downloaded 55 times
In most of these cases it is a Windows rights problem, make sure that the necessary files have all access rights.
(Antivir; WindowsDefender and the like may interfere with this if the -.exe files in the Enderal folder are blocked,
see also mentioned Steam Discussion)
Another possibility are errors in the configuration files
please delete the 2 -.ini files under ...\Documents\my games\Enderal (Enderal.ini and EnderalPrefs.ini)
You can also temporarily disable one or more of the optimizations, these are ENBoost; OneTweak or OSAllocators.
(in the Launcher under Settings/Optimizations)
then try again.
then try again.
Thank you, the problem was the ENBoost optimization option. After disabling it the games runs normally.
