8 posts • Page 1 of 1
Hello
I have a small problem, after the quest of RYNEUS, the colors become really dull. The game is almost black and white.
The color became very strange and dark after the last fight.
before:
after;
after2 (long time after always darkly);
I tried on two different computer
Thanks for yours answers
after2
after2
after 2.jpg (488.39 KiB) Viewed 1989 times
before
before
after
after
hi, welcome to the forum :)
do you use any mods? deactivate (ideally uninstall) them.
can you reload an earlier save and play the last quest (without potential mods) again?
if that doesn't work attach savegames (ideally manual, no auto- or quicksaves) please,
one before and one after the bug appeared.
they're found in (...\Documents\My Games\Enderal), we'll need the *.ess and the *.skse file;
pack both to a zip/rar/whatever archive, (the forum doesn't accept *.skse)
thank you :)
thank for replay.
no mods.
the save is just before the bug, after the dead of the boss the bug appear.
https://forum.sureai.net/download/file. ... ew&id=6776
Maybe you still have a savegame for us before entering the settlement for the very first time.
(if possible just before the rockfall outside in front of the Toor)
Maybe you used cheats or mods there sometime?
(e.g. "fast travel" or "wait - no heal" ..., as cheat: coc or similar)
Have you ever left "silver grove" in between or have you already entered it before the quest?
hello, thanks for your replay
No cheat or mod but i have used translation files to french when i have begin the game. Now i use the steam version.
when I saw the bug for the first time, i have used an old save to continue the game.
this is the save for first time in "silver grove" just before the last Ryneus's wish :
https://forum.sureai.net/download/file. ... ew&id=6778
Thanks you
In the normal version the error does not occur, but with your savegame we cannot solve the problem.
That you started the game with an unfinished / incorrect translation (and then switch between) is very very bad.
Such a thing shoots up a lot of things and nobody knows the long-term consequences for your savegame.
so these are your options:
-install Enderal new
(to remove all the remains of the mod, you should delete the folder:
...\Steam\Steam\SteamApps\common\Enderal
Then repair Enderal with steam.)
You can select the English or French version in Steam.
(French is currently available through Steam from the French team, but this will not help for your current play)
START A NEW GAME
or
-try to load an earlier save (BEFORE Silberhain, e.g. from the possessed before).
for this you will need to REINSTALL Enderal AND use your old translation mod.
Even if the bug should be fixed, there may be other problems and then we won't be able to help you,
and there is no guarantee for success.
this option does not work.
I'm sorry there's no better answer.
Thanks for your Replay.
I' will reinstall the game and restart.
This is not a problem because i love this game ;)
