Hello! I noticed a purple sign for the Dancing Nomad in Ark and was wondering what mesh and texture file path it's using? I have signage meshes installed for "Blowing in the Wind" mod and am thinking that might be the issue, so wanted to remove the conflicting mod file. Thanks so much!
Is your problem solved or do you still have questions?
Hi there! Still looking for a solution, I haven't been able to isolate which texture/mesh is causing the purple sign per the screenshot.
Thanks, instead of disabling each mod at a time is it possible to detect which mesh/texture this specific sign is using instead? I tested and it doesn’t seem to affect any other sign, just this one, so I’m not sure it’s even mod related.
You are probably looking for these details...
E - Meshes.bsa - meshes - enderal - architecture - ark - signdancingnomad.nif
The texture is referenced in the SignBanneredMare02 NiTriShape and uses...
E - Textures2.bsa textures\enderal\architecture\ark\dancingnomadinnsigndv.dds
Recently I raised a bug that pointed out that the mod was using the German texture in the English game and the texture used in the mesh was probably changed from dancingnomadinnsigndv.dds to dancingnomadinnsignev.dds (I have not checked the meshes recently).
I suspect your signeage mod needs changing for the English version of Enderal to reflect this.
Several other signs for the Bath House and Fat Leoran were addressed at the same time.
Oooh, gotcha! Thank you so much for your reply!
