6 posts • Page 1 of 1
Hello,
I'm having trouble with the npc (Esme) not showing up in the Museum after we found the statuette inside the house in the nobles' quarter's. I think the Npc is stuck or something. This can be fixed with the npc ID, I can simply summon them to me and that would solve the problem, but I just can't find that particular npc's ID anywhere.
Any help is appreciated.
Thanks
please keep your hands off the console until you're asked to.
This can break more, even in the later game.
Could you upload a savegame please?
You found it in ...\Documents\My Games\Enderal\Saves,
we'll need the skse and the ess of a manual (no quick- or auto-) save.
Pack them to a rar or zip archive and attach them to a post here
Good would be also a second savegame before the problem, thus from the penultimate Quest section
Hey
Save files are attached. Save #7 is the recent save with the problem. #6 is before the problem.
Saves.rar
(4.36 MiB) Downloaded 243 times
did you try the earlier save?
because that works fine on my side.
(even if it's just to see if it works, I know that there's some time between them ;) )
if she doesn't appear again, it might be the fault of one of your mods (fast travel probably)
if it doesn't work without any mods either you might want to let Steam verify your game files
BUT
you probably don't want to replay your progress anyway.
(would be safer though, no guarantee that this doesn't cause problems later on)
(it shouldn't though)
- load a safe in which you stand next to Esme
- open the console and click on her (the console should show you some infos about her)
- close the console
- load the later save, enter the museum
- open the console, type
moveto player
(confirm with ENTER)
- close the console, Esme should appear next to you, continuing the quest
hope that helps :)
Just curious, before you went to the museum, did you go talk to Esme where she is sitting on the steps by the lake?
I tried to find her by the river, but I couldn't. I then tried to turn off collision and see where she was from an adjacent area, and there she was, sitting by the river, where I couldn't see her before. I turned off collision and talked to her, but I still didn't see her in the museum afterwards. Also, I replayed my previous save, and everything worked out fine, she was by the river and all. But I put more time now and I don't want to replay 5hr+ of content, and I can't just skip a big quest like this one, there's a lost fragment in the castle location in the quest as well, so it's a big deal. I really think it's a good idea to try out the npc ID for now and see what happens, it won't hurt, since it's not working right now anyway.
Note: Will test the solution provided by the mod, and edit this post with the result.
Edit: urst's solution using the console has worked.
Thank you so much for your readiness to help and your persistence.
