I have downloaded Enderal from Steam but when I launch it i see just the starting image with no way to interact. If I press Enter it asks me if i want to start from a saved game but it doesn't start with any answer.
Someone can help me?
Thank you
Max
Thank you
Max
hi, welcome to the forum
you are probably using a different screen resolution than 16:9 / 16:10?
you should either adjust your resolution in the EnderalPrefs.ini to max 2560x1440,
(via launcher or ... \Documents\My Games\Enderal)
or use FlawlessWidescreen
hope that helps
hope that helps
Thank you for answering,
I understand that the problem is that something is out of my screen?
I have a 4:3 monitor and play at 1280x1024 so i can't play this mod?
of course you can play
(most people with this problem just have some super wide screen and a higher resolution, that's why i didn't think of 4:3)
you just need to try a different screen resolution (for Enderal), 1280×720 should work.
if you disable Borderless Fullscreen in the "General" - tab you can manually add any resolution.
( to be honest, you may have to play around with the options marked in the screenshot,
not sure which one would fit in this case
I managed to run it @ 1280x720 16:9 with Exclusive Widescreen selected
Thank you very much for the help Urst
nice, good to know it worked,
have fun playing
have fun playing
