11 posts • Page 1 of 1
Confused about stances
Post by Greybird »
This doesn't seem to be explained anywhere. I know that you can only have one stance at a time. I've taken two: Skaraggian Stance and Warrior Stance.
If I go into the magic menu, select Skaraggian stance and hit my 'talent/power' key, I do an animation and get a message:
Skaraggian Stance Ended
I hit the key again:
Qyranian Stance Ended
Skaraggian Stance Taken
Qyranian Stance? I haven't even taken any points in blade dancer.
I hit it again:
Again:
Qyranian Stance Taken
I have no idea how to control these things. And I still can't find Warrior stance.
Re: Confused about stances
Post by urst »
hi, welcome to the forum :)
could you attach a savegame (no auto- or quicksave) please?
they're found in (...\Documents\My Games\Enderal).
we'll need the *.ess and the *.skse file;
pack both to a zip/rar/whatever archive,
(the forum doesn't accept *.skse)
thank you :)
Absolutely, and thank you.
Saves.zip
(1.11 MiB) Downloaded 698 times
Post by urst »
thank you :)
before you read anything else - please disable Enhanced Blood.
uninstall the mod or at least only use the textures, the mod is the reason for a mainquest - blocker.
that said.
i have the same issue on your save as you. and i am wondering how you managed to activate 13(?) memories on Level 7.
did you cheat these points? if so, in what way?
that bug is very likely a result of that.
(i don't remember reading about that problem before, too)
so, i'm sorry, but we can't really help you here :(
only thing would be to load an earlier save and to level without cheating.
No, I absolutely did not cheat. I'd never even activated the console.
I didn't know I was getting any more than I was supposed to. I do seem to remember getting some extras from... something. An early reward, perhaps?
Actually, I just hit level 8 and meditated. I have one unspent point, one on Tempest, and seven on the Vandal tree. No others. That's nine points at level 8.
Post by urst »
sigh. no you didn't cheat, i'm an idiot :roll:
you have my apologies.
(i thought several memories were maxed out.
it just wasn't possible to incease them because there were no memory points -.-
i'm sorry)
that doesn't explain the stance issue, then.
did you have any mods installed that you later uninstalled?
(sometimes stuff just stays in your save)
otherwise we'll think about that a bit and get back to you :)
Nope. I'm pretty familiar with ES modding, all the way back to Morrowind. I run a maxxed-out Skyrim mod set, and was one of the original authors of DarkUI for Oblivion. I'm careful about what I add to my games, and with how I remove them.
Post by urst »
ok, this seems to be an actual bug :oops:
could you create a bugticket in the tracker (with attached savefile), please?
thank you :)
Ah, well - thank you. At least I know I'm not doing something wrong. I'll file the report shortly.
For my own edification, where would warrior stance appear if it were working correctly?
Post by urst »
tbh i have no idea, i've never played a warrior.
i'd say it should appear right besides the other "special powers" (and the other stance)
and, as a general suggestion: maybe save a bit more often on new slots.
you really don't want to loose several hours of gameplay just because of something went wrong :)
