The affinity from "Shadow Dancer" does not work properly, it says (if an enemy dies shortly after you marked him with "Ghostwalk" they will be resurrected to fight on your side.) the problem is you can't mark an enemy with "Ghostwalk" because if you activate "Ghostwalk" it will just teleport you and make you invisible but you don't get any kind of targeting mode.
Thanks and i hope you are going to fix this bug. I appreciate your hard work, and thanks for this amazing game.
Welcome to the forum
And thank you for your hint!
The problem is known and already noted in the bugtracker (in German). ID 0000933
