Good day everyone!
So those sounds have stopped working, and i have tried the remove music command, what can i do?
hi, welcome to the forum
do you happen to have Enderal installed on an external harddrive or even not on c:\?
the engine apparently doesn't like that sometimes
if not, do you have an "unconventional" speaker setup which might have to get adjusted?
more about both here and there
(we also had two german threads if you want to take a look)
hope that helps
hope that helps
Oh maybe I can try moving it to c, thank you!
I have tried changing the file directorry, didn't work... I also haven't got skyrim unofficial patch installed and it's enderal's standalone instalation
It worked fine for a few hours though, the sounds stopped playing for some reason
Skyrim mods are not needed (or supported by us)
and Enderal would probably not even launch with the unofficial patch installed
I just reread you first post, sorry.
if these sounds worked before, can you load earlier saves to check if they still have sound?
do you have any mods installed?
Yeah! An earlier save does work
And i have this mods:
Enhanced camera
Marketplace house redone
Classic main menu
Gameplay overhaul
Phasmalist overhaul
Tracking tool
All downloaded from the workshop
Thank you for your attention!
Enhanced camera
Classic main menu
Gameplay overhaul
Phasmalist overhaul
Tracking tool
hm.
these mods do seem harmless.
please check their comments sections though if anyone has had similar problems
do you remember when you realized that there's a problem?
(specific part of a quest, after a crash, something like that?)
just reloading a working save would probably be easiest :/
if that's completely out of the question, could you attach a savegame, please?
found in ...\Documents\My Games\Enderal\Saves, we'll need the *.skse and the *.ess of a manual (no quick- or auto-) save
pack them to a rar or zip archive and attach them to a post here
I was exploring Goldenfrost and Wellwatch when it happened, here's the rar!
Nuevo Archivo WinRAR.rar
(2.55 MiB) Downloaded 87 times
thank you
the sound seems to be completely fine on this save o_o
i resaved your game, could you try loading that
(maybe don't keep playing though, not sure what happened to stuff stored in your player home)
if that doesn't work it really seems to be something on your end.
- do you maybe have any particular sound software installed?
- are your drivers up-to-date?
- as stupid as it sounds, maybe readjust the cables?
TEST.zip
(1.46 MiB) Downloaded 100 times
Still doesn't work
I don't have software installed, nor anything weird with the aoudio, maybe updating the drivers will solve it!
Maybe something to do with "silencelongtransitionhighpriority"?
04.03.2019 21:36ThePietromancer wrote: Maybe something to do with "silencelongtransitionhighpriority"?
if cheats worked in this case we would have had the same issue with your save :/
or at least, my save would work on your end.
Ok, looks like it's working now with your save, thank you very much!
05.03.2019 17:13ThePietromancer wrote: Ok, looks like it's working now with your save, thank you very much!![]()
well. good to know
(no idea what could cause this, so let's just accept it as a success)
