I found the blueprint for the "fingers" but the cost to craft it is quite high, including 3 Thorium ingots, 3 shadow steel ingots, 2 moonstone ingots, etc. And the stats don't seem to me as good as the Ash Warrior gloves. When I check the Wiki I see the other 3 parts of this set each require the same components to craft, so even if you managed to obtain all 4 blueprints, the costs in rare ingots is tremendous (12 thorium ingots, 12 shadow steel ingots, plus more), and the stats don't look to me to be worth the cost. Has anyone made a Venturer set and used it?
