8 posts • Page 1 of 1
cast the spell on the door? havent been able to actually get one of these to work, figured id finally make a post about it. currently trying to use an expert scroll on an expert lock and no matter what i try i cant get it to open the door
Which door do you mean? Not all can be opened like that.
Could you otherwise upload a savegame please?
They're found in ...\Documents\My Games\Enderal\Saves, we'll need the skse and the ess of a manual (no quick- or auto-) save
pack them to a rar or zip archive and attach them to a post here :)
Doors are wierd, I have had some success by using the scroll on the middle of the door at the very bottom basically half aiming at the door and half aiming at the ground.
I have yet to have a Ondusi scroll work on a door by actually aiming at it.
We would have to try to reproduce the problem. That's why the question of a save.
I have postponed your post in support.
Same... i aim the scroll on the lower half of the door. But i mean... since i know it is just a problem with the "location of the acutual lock" i quicksave before every attempt to open a lock with a scroll and load new if i aim not right. Repeat this if you need to use more than the first scroll. I not missed more than two times...
So no problem for me. :D
I do quicksaves, too. The small locks on chests can only be opened if you stand directly in front of it and aim at the lock itself. Doors never did open for me. :?: So I had the same problem.
And the safes in the bank cannot be opened at all with scrolls, I think.
Maybe its a bug for you...
But the bank safes should open with scrolls too. It worked for me. ;)
Aim here under the safe door inside of the wall... on normal chests try to aim on a bit under the textured lock... and for the little jewelery boxes i aim straight on it and it worked allways first try.
I aim on the ground in front of a door or chest. Works fine for me.
