During the quest In Our Shadows, I am following Tharael after the day long wait. We reach our final destination and he leads me to the hidden door. Now, I know the hidden door is there because I was exploring on my own and successfully got inside by TCL'ing through the door, pulling the chain, and the doors opened no problem. But while I am here with Tharael, he knocks, the doors open...... but the wall of the building is in the way. So the man behind the door tells me to stay where I am... and attempts to walk through the wall to get to me. For obvious reasons, that doesn't work.
I managed to force it to work correctly by turning on TCL when the man behind the wall tried to walk towards me, so that eventually, he did walk through the wall and over to my side. But to gamers less accustomed to toggling collision on and off this would be confusing and frustrating.
Screenshot of problem.
hi, welcome to the forum
usually stuff works if you don't tcl your way through everything
honestly, please absolutely ONLY use tcl if you're stuck between some rocks or something.
we can't help you if you run into plotstoppers because of this
(and yes, you will miss crucial triggerboxes if you just float trough them.
only thing to do at such a point would be to load an earlier save)
(same with setStage btw. don't.
