2 posts • Page 1 of 1
I'm not able to post to the other forum. I guess that forum is closed down, although it doesn't tell me why. This is from the original quest line but it is the expansion version of the game from steam.
At the end of the quest "The shards of order, part I" there is a door you're supposed to teleport through to the next area and start to the quest "The shards of order, part II.". It's bugged for me and I can't go through it.
Tealor tells Yuslan to open it, he goes through his magic animation, then Tealor tells you to lead the way, you know what we're looking for. Then I can't open it. It says "requires key."
I have tried console command unlock, which just reveals more wood behind the door, and clipping past it shows it is meant to be a portal, not just a door.
I have tried reloading earlier saves and playing through again, but keep encountering the same problem.
Could someone share what a useful command would be at this point? I'd like to just advance to the start of the next quest, and teleport to that area, unless someone has a better suggestion.
This is on the map Undercity, Crow Quarter.
Attached a few screenshots of the quest, the dialog, and the door showing that it is locked. Opening the door is just a wooden wall behind it so I think it is meant to teleport you to a new area. That teleport isn't happening, something seems to be stuck.
(Related reddit post: https://www.reddit.com/r/enderal/commen ... rt_1_cant/)
download (1).jpg (284.79 KiB) Viewed 2697 times
Update: It looks like that door wasn't the door they were supposed to open, but a passage nearby. They didn't open that passageway either, but using "tcl" i discovered a different passageway and was able to advanced the quest. Problem averted!
