Hey,
so I've gotten the "Shadow of Transcience" mount by helping the Father, but it seems to be bugged. While I am mounted, i can only run forward. Trying to go in other directions only causes me to go forward further, no idea what might cause this.
My mods are Gameplay Overhaul, Enhanced Blood Textures, HelmetToggle and SmartCast. Don't think these should cause any issues.
I also attached a save, hope this helps
Save 520 - WolvesNeedNoArmor Dark Valley 46.40.09.ess
(4.49 MiB) Downloaded 89 times
we'll need the *.skse as well; the forum doesn't accept the file though,
you'll need to pack it to a zip or rar archive or something
and, while we don't support mods in general, please throw out Enhanced Blood Textures.
it causes at at least on point in the mainquest issues
(using only the textures might be ok)
unfortunately I can't load your Savegame (crash), it doesn't work without the mods you use. I would suspect that the Savegame itself is broken, maybe exactly by these mods (which I can't test but)
hmm, that sounds pretty concerning.. but couldn't it simply be that i am using content which is exclusive to the gameplay overhaul mod and that without it my save will crash? Because i have items that exist only in that mod? I would test it myself but I am a bit hesitant to disable gameplay overhaul because the mod creator suggested not to do that mid-playthrough and i'm scared it's gonna break stuff if i do disable it.
hm, maybe try with only the overhaul installed.
if it's still bugged, contact the mod author about the issue
