I just installed a fresh copy of the new expansion, no mods yet, however the selected quest objectives do not want to show themselves while I'm walking around. Is there a problem or am I missing something?
If you are talking about a copy, do you mean the normal installation via Steam?
Did you install everything correctly or did you change suggested paths?
See instructions:
Were the folders empty or already used by something?
Otherwise you can also upload a savegame here.
found in ...\Documents\My Games\Skyrim\Saves, we'll need the skse and the ess of a manual (no quick- or auto-) save
pack them to a rar or zip archive and attach them to a post here
PS:
not all quests have markers, some will come up when you play attentively. Or you just didn't activate the quest?
See instructions:
PS:
Yes, a normal installation via Steam. I used the default path, and it created it's own new folder in the C:\Program Files (x86)\Steam\steamapps\common path, called "Enderal". All of the installation files are stored there. I made sure multiple times that the quests were enabled. The save files requested are also attached below, also. Thanks in advance for the help.
Ralkero Enderal Saves.zip
(614.96 KiB) Downloaded 74 times
You are still at the very beginning of the game, there is no marker for the current quest, because you can only continue this way.
So everything is ok^^
22.02.2019 23:07Stefanie wrote: You are still at the very beginning of the game, there is no marker for the current quest, because you can only continue this way.
