9 posts • Page 1 of 1
I recently downloaded Enderal on steam, and the launcher doesn't seem to work.. Ive done everything
Make everything run as admin
make sure firewall isn't blocking it
verify cache
the start button doesn't work, it acts like I'm not even pressing the button in the first place.
tell me what anymore information ya need and ill try to give it.
hi, welcome to the forum :)
you asked about the issue on discord first, and said you tried mostly everything, yes?
(I'm mostly active in the forums, didn't follow to closely)
could you attach the launcher.log, please? it's located in ...\Enderal\Enderallauncher\system\log :)
Sure
Launcher.log
(67.49 KiB) Downloaded 218 times
thank you :)
the log looks ok to me,
so I can't do to much right now but take some stabs in the dark and hope to hit something ;)
(sorry)
- you probably did try to reinstall already?
- the steam library is installed on Z:/, is that an internal or an external drive?
if the latter, try to install Enderal internal
- is your system in any way "extraordinary"? (dunno, are you trying to emulate Windows on a Linux sytem or something)
the game is installed in my ssd drive.. and no its just windows 10
after switching the installation on my normal 2tb drive, it still doesnt work.. same results.
If nothing works, start the game via ..\Steam\steamapps\common\Enderal\skse_loader.exe in your game folder.
that has worked, but all the cut scenes are broken.. and i refuse to play the game if i can't enjoy the whole experience... ya know...
Apparently my game was running itself under a different name of skyrim (cause when i tried to delete it it said some program was using it, and nothing in task manager was called skyrim, enderal, skse, or anything similar) so i reset my computer and deleted the file.. and reinstalled the game.. so now the launcher works.. now to the next problem.. ill go make a new post for that.
