I was wondering what Field of View value folks who play at 21:9 tend to prefer when in first person? I am playing on a single monitor at 2560x1440.
It has been ages since I have played either Skyrim or Enderal and I have tried values from the default (75 I think?), 80, 85 and 90 but cannot find a setting that I find comfortable when turning. I am aware of how the FOV affects the zoom on the screen and the amount of fisheye but my brain is telling me it cannot understand the movement it is being shown and I am getting a motion tiredness very quickly.
Any suggestions for me?
17.02.2019 08:17DanielCoffey wrote: I was wondering what Field of View value folks who play at 21:9 tend to prefer when in first person? I am playing on a single monitor at 2560x1440.
Only 2560x1080 @144hz here and I tend to run 90 fov in Enderal, I don't know if having a very curved monitor (had the tightest radius at release) reduces any fisheye effect, but I find running any game at default 16:9 fov with the extra width of the monitor feels restricted and slightly "off"...plus I tend to end up closer to the screen the more I get into the game so the added fov feels good, almost starting to wrap round.
Are you getting a smooth constant frame rate, or is it wildly varying?
Maybe reduce the mouse speed so you're not turning too fast maybe?
Enable / disable Motion Blur?
17.02.2019 08:17DanielCoffey wrote: I am getting a motion tiredness very quickly.
There is motion blur? That can come off if there is.
I get a rock steady frame rate when I display it via ENBoost (num*) as I am running a 1080ti and no AA. I have reduced the mouse sensitivity a little but I find the effect is a bit worse when I am holding out the hands for spell casting and moving. No idea what my brain doesn't like but it certainly finds something off kilter.
Maybe try with max aa and see if the removal of the jaggy bits helps with the movement. My 1080 is away for testing so only using an old r9 270x 2gb and that runs Enderal at ultra settings and maxed all settings so you shouldn't have any problems at all with your 1080ti
Quick thought while typing and you saying about holding your hands out, is there depth of field? and is it enabled? as I find that can be distracting if the screen is trying to focus other than where my eyes are looking....if that makes sense?
Unless ENBoost adds any effects, I have not changed anything from the default settings except for a few small non-visual mods.
I know that UseEffect=false in enbseries.ini so all that stuff is off.
