5 posts • Page 1 of 1
Sobald über den Launcher Enderal gestartet wird stürzt Skyrim ab. Eine Neuinstallation hat nichts gebracht.
Durch die Deaktivierung von ENBoost läuft das Spiel.
[+] launcher log
[[ Starting Launcher ]]
Log started at 2019/02/15 16:25:53
If you encounter any issues with the Enderal Launcher, this file might be helpful for fixing it.
Please use our Bugtracker at http://tracker.sureai.net to report this problem.
Release ID: A65
Release version: Steam
Build date: 14.02.2019 20:32:21
Creation date: 14.02.2019 20:32:21
App start location: C:\Program Files (x86)\Steam\steamapps\common\Enderal\
App game folder: Enderal\
Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
NET Versions: 4.6 or later
Language: DE
Build version: 1.5.0.0
Game version: 1.5.0.0
Internet connection: True
Installation status: True
Steam status: True
OneTweak status: True
ENBoost status: False
Directory search status: True
Master found: True
SKSE found: True
Last external startup path: 0
Last external executable: 0
> Start logging:
<16:25:53> Conf - Initialize conf file
<16:25:53> Conf - Initialize conf file [DONE]
<16:25:53> Conf - Save conf file
<16:25:53> Conf - Save conf file [DONE]
<16:25:53> Conf - Checking Environment
<16:25:53> Conf - Checking Environment [DONE]
<16:25:53> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal\EnderalLauncher\system\ recursive
<16:25:53> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal\EnderalLauncher\update\ recursive
<16:25:53> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal\EnderalLauncher\backup\ top level
<16:25:53> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal\ top level
<16:25:53> Main - Initialize Unpatcher
<16:25:53> Unpa - Start cleanup
<16:25:53> Main - Unpatcher [DONE]
<16:25:53> Main - Create environment
<16:25:53> Main - Create environment [DONE]
<16:25:53> Main - Initialize network
<16:25:53> Net - Connection enabled in settings
<16:25:53> Net - System is connected to network
<16:25:53> Net - Try to establish server connection thread
<16:25:53> Net - Thread STARTED
<16:25:53> Main - Initialize network [DONE]
<16:25:53> Main - Initialize intervall
<16:25:53> Net - Choose server
<16:25:53> Main - Initialize intervall [DONE]
<16:25:53> Net - Server connection attempt #1
<16:25:53> Main - Initialize PanBase [DONE]
<16:25:53> Main - Initialize CPanel
<16:25:53> Cp - Cp Initialisation
<16:25:53> Main - Initialize CPanel [DONE]
<16:25:53> Cp - Try to compare server with local file
<16:25:53> Conf - Hardware Scan:
<16:25:53> Conf - CPU: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz, Speed: 2401, Cores: 8
<16:25:53> Conf - GPU: Intel(R) HD Graphics 4000, Memory: 0 GB
<16:25:53> Conf - RAM: 7 GB
<16:25:53> Conf - DISC: 38902 MB
<16:25:53> Cp - Connection port: 80
<16:25:53> Cp - Connection default port: True
<16:25:53> Cp - Connection proxy bypassed: True
<16:25:53> Cp - Connection OK
<16:25:53> Cp - 14.02.2019 12:15:34 14.02.2019 20:08:13
<16:25:53> Cp - Up-to-date
<16:25:53> Cp - Check Cp file
<16:25:53> Cp - Read old Cp file
<16:25:53> Cp - Abort: Check existing Pics
<16:25:53> Cp - Start Cp pic checker
<16:25:53> Cp - All pics found
<16:25:55> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<16:25:55> Settings - <LOAD> iPreloadSizeLimit done [2684354560]
<16:26:11> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal\ top level
<16:26:12> Settings - Settings saved
<16:26:23> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<16:26:23> Settings - <LOAD> iPreloadSizeLimit done [2684354560]
<16:26:24> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Enderal\ top level
<16:26:25> Settings - Settings saved
<16:26:26> Settings - <LOAD> Parsing fSplitDistanceMult done [0,75]
<16:26:26> Settings - <LOAD> iPreloadSizeLimit done [2684354560]
<16:26:28> Settings - Open Launcher log
Well, you could try editing certaiin settings in ENBoost's enblocal.ini to see what specifically triggers your ctd. But, if your game runs stable without it, then go for it, I guess.
Willkommen im Forum!
Wenn es bei dir nur ohne ENBoost startet wäre das schade. Was wir eingebaut haben ist ein allround built der auf den meisten Systemen funktionieren sollte.
Man kann es individualisieren (und ich glaube viele die sich damit auskennen werden das auch tun). Es gibt aber zig Möglichkeiten die individuell vom System abhängig sind und anderen Usern somit wenig oder gar nichts nutzen.
Offiziell können wir das zeitlich nicht unterstützen. Aber ich werde mal versuchen dir privat zu helfen :wink:
Thanks for the help. Which settings would make most sense to edit first?
Perhaps it make sense to consider that I am using a Laptop with an integrated Intel GPU and a second nvidia GPU. This sometimes creates issues.
Lies bitte deine PN :wink:
