I installed Enderal in a clean Skyrim. The launcher won't work and I can't find a reason or a solution anywhere. When I press launch enderal, it says that the game needs an update. The updater says that is up to date. When I press to see the Data Files, it doesn't show any file.
I am unable to see what is the problem. The installer worked and the configuration looks fine. The only thing that the log tells me is "Master found: False" but App start location points in the right folder.
I will put the log here.
UPDATE: So, I think I have some file missing?
As a test, I tried to launch the game from the SKSE executable and it showed me an error that said that Update.esm needed Skyrim.esm. I checked the Data folder and I didin't found the Skyrim.esm, so I copied it from the backup and I was able to launch it (Altrough I didin't was able to start the game, just see the main menu).
As a test, I copied the entire original data, but that didin't work.
Code Select all
[[ Starting Launcher ]]
Log started at 2018/12/11 22:34:10
If you encounter any issues with the Enderal Launcher, this file might be helpful for fixing it.
Please use our Bugtracker at http://tracker.sureai.net to report this problem.
Release ID: A65
Release version: Skyrim Classic
Build date: 11/12/2018 22:09:07
Creation date: 11/12/2018 21:45:26
App start location: C:\Program Files (x86)\Bethesda Softworks\The Elder Scrolls V Skyrim - Legendary Edition\
App game folder: The Elder Scrolls V Skyrim - Legendary Edition\
Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
NET Versions: 4.6 or later
Language: EN
Build version: 1.1.0.0
Game version: 1.2.5.0
Internet connection: True
Installation status: True
Steam status: False
OneTweak status: True
Directory search status: True
Master found: False
SKSE found: True
Last external startup path: 0
Last external executable: 0
Backup path Enderal: path
Backup path Skyrim: C:\Program Files (x86)\Bethesda Softworks\The Elder Scrolls V Skyrim - Legendary Edition\EnderalLauncher\backup\skyrim\
> Start logging:
<22:34:10> Conf - Initialize conf file
<22:34:10> Conf - Initialize conf file [DONE]
<22:34:10> Conf - Save conf file
<22:34:10> Conf - Save conf file [DONE]
<22:34:10> Conf - Initialize Version
<22:34:10> Conf - Checking Environment
<22:34:10> Conf - Checking Environment [DONE]
<22:34:10> Func - RWP: C:\Program Files (x86)\Bethesda Softworks\The Elder Scrolls V Skyrim - Legendary Edition\EnderalLauncher\system\ recursive
<22:34:10> Func - RWP: C:\Program Files (x86)\Bethesda Softworks\The Elder Scrolls V Skyrim - Legendary Edition\EnderalLauncher\update\ recursive
<22:34:10> Func - RWP: C:\Program Files (x86)\Bethesda Softworks\The Elder Scrolls V Skyrim - Legendary Edition\EnderalLauncher\backup\ top level
<22:34:10> Func - RWP: C:\Program Files (x86)\Bethesda Softworks\The Elder Scrolls V Skyrim - Legendary Edition\ top level
<22:34:10> Main - Initialize Unpatcher
<22:34:10> Unpa - Start cleanup
<22:34:10> Main - Unpatcher [DONE]
<22:34:10> Main - Create environment
<22:34:10> Main - Create environment [DONE]
<22:34:10> Main - Initialize network
<22:34:10> Net - Connection enabled in settings
<22:34:10> Net - System is connected to network
<22:34:10> Net - Try to establish server connection thread
<22:34:10> Net - Thread STARTED
<22:34:10> Main - Initialize network [DONE]
<22:34:10> Main - Initialize intervall
<22:34:10> Main - Initialize intervall [DONE]
<22:34:10> Main - Initialize PanBase
<22:34:10> Net - Choose server
<22:34:10> Net - Connect to [DL1]
<22:34:10> Net - Server connection attempt #1
<22:34:10> Main - Initialize PanBase [DONE]
<22:34:10> Main - Initialize CPanel
<22:34:10> Cp - Cp Initialisation
<22:34:10> Main - Initialize CPanel [DONE]
<22:34:10> Cp - No connection to server established yet, try again in 5 seconds...
<22:34:10> Cp - Check Cp file
<22:34:10> Cp - Abort: Cp file to short
<22:34:10> Conf - Hardware Scan:
<22:34:10> Conf - CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz, Speed: 3601, Cores: 8
<22:34:10> Conf - GPU: NVIDIA GeForce GT 740, Memory: 2 GB
<22:34:10> Conf - RAM: 7 GB
<22:34:10> Net - Connection port: 80
<22:34:10> Net - Connection default port: True
<22:34:10> Net - Connection proxy bypassed: True
<22:34:10> Conf - DISC: 524503 MB
<22:34:11> Net - Connection OK
<22:34:11> Net - Start listing available versions on [DL1]
<22:34:11> Net - 1.1.3.0 F 1
<22:34:11> Net - 1.1.7.7 B 1
<22:34:11> Net - 1.1.8.5 S 1
<22:34:11> Net - 1.1.9.5 S 1
<22:34:11> Net - 1.2.1.5 S 1
<22:34:11> Net - 1.2.2.9 S 1
<22:34:11> Net - 1.2.3.0 M 1
<22:34:11> Net - 1.2.3.1 L 1
<22:34:11> Net - 1.2.3.8 S 1
<22:34:11> Net - 1.2.3.9 M 1
<22:34:11> Net - 1.2.4.0 L 1
<22:34:11> Net - 1.2.4.1 M 1
<22:34:11> Net - 1.2.4.9 S 1
<22:34:11> Net - 1.2.5.0 M 1
<22:34:15> Cp - Retry thread started attempt #1
<22:34:15> Cp - Try to compare server with local file
<22:34:15> Cp - Connection port: 80
<22:34:15> Cp - Connection default port: True
<22:34:15> Cp - Connection proxy bypassed: True
<22:34:15> Cp - Connection OK
<22:34:15> Cp - 20/11/2016 7:03:29 11/12/2018 21:45:35
<22:34:15> Cp - Up-to-date
<22:34:15> Cp - Check Cp file
<22:34:15> Cp - Abort: Cp file to short
<22:34:25> Conf - Save conf file
<22:34:25> Conf - Save conf file [DONE]
<22:34:25> Exit(A)
Enderal requires a clean Steam installation of Skyrim - before working on Enderal, I recommend sorting that out. Install Skyrim (32bit) via Steam, ideally not in a windows folder and not on an external hard drive, and test if it works. If Steam Skyrim works and Enderal does not, then there is something else at play.
Once you have made sure, that Skyrim runs properly, you need to install Enderal again - here is a handy guide.
So yeah, the problem was the folder. I supossed that wasn't the problem because I was using the launcher as administrator, but I guess that wasn't enough.
Thanks for the help.
