Hello,
I have a problem with Enderal .Itfreeze at the start picture and No show directory.
MY launcher and installation file dowload to Enderal.com and i use Torrent - SureAI.net ,launcher is "A65".
My skyrim is clean.I have reinstalled several times.but is not work.
This is all that comes up on the launcher log
thank you for your help.
[[ Starting Launcher ]]
Log started at 2018/11/18 18:14:04
If you encounter any issues with the Enderal Launcher, this file might be helpful for fixing it.
Please use our Bugtracker at http://tracker.sureai.net to report this problem.
Release ID: A65
Release version: Skyrim Classic
Build date: 2018/11/18 下午 05:48:44
Creation date: 2018/11/18 下午 05:48:55
App start location: D:\Program Files (x86)\Steam\steamapps\common\Skyrim\
App game folder: Skyrim\
Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
NET Versions: 4.5 or later
Language: EN
Build version: 1.1.0.0
Game version: 1.2.5.0
Internet connection: True
Installation status: True
Steam status: True
OneTweak status: True
Directory search status: True
Master found: True
SKSE found: True
Last external startup path: 0
Last external executable: 0
Backup path Enderal: path
Backup path Skyrim: D:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\
> Start logging:
<18:14:04> Conf - Initialize conf file
<18:14:04> Conf - Initialize conf file [DONE]
<18:14:04> Conf - Save conf file
<18:14:04> Conf - Save conf file [DONE]
<18:14:04> Conf - Initialize Version
<18:14:04> Conf - Checking Environment
<18:14:04> Conf - Checking Environment [DONE]
<18:14:04> Func - RWP: D:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<18:14:04> Func - RWP: D:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<18:14:04> Func - RWP: D:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<18:14:04> Func - RWP: D:\Program Files (x86)\Steam\steamapps\common\Skyrim\ top level
<18:14:04> Main - Initialize Unpatcher
<18:14:04> Unpa - Start cleanup
<18:14:04> Main - Unpatcher [DONE]
<18:14:04> Main - Create environment
<18:14:04> Main - Create environment [DONE]
<18:14:04> Main - Initialize network
<18:14:04> Net - Connection enabled in settings
<18:14:04> Net - System is connected to network
<18:14:04> Net - Try to establish server connection thread
<18:14:04> Net - Thread STARTED
<18:14:04> Main - Initialize network [DONE]
<18:14:04> Main - Initialize intervall
<18:14:04> Main - Initialize intervall [DONE]
<18:14:04> Main - Initialize PanBase
<18:14:04> Net - Choose server
<18:14:04> Net - Connect to [DL5]
<18:14:04> Net - Server connection attempt #1
<18:14:04> Main - Initialize PanBase [DONE]
<18:14:04> Main - Initialize CPanel
<18:14:04> Cp - Cp Initialisation
<18:14:04> Main - Initialize CPanel [DONE]
<18:14:04> Cp - No connection to server established yet, try again in 5 seconds...
<18:14:04> Cp - Check Cp file
<18:14:04> Cp - Abort: Cp file to short
<18:14:04> Conf - Hardware Scan:
<18:14:04> Conf - CPU: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz, Speed: 3301, Cores: 4
<18:14:04> Conf - GPU: NVIDIA GeForce GTX 970, Memory: 4 GB
<18:14:04> Conf - RAM: 8 GB
<18:14:04> Conf - DISC: 100699 MB
<18:14:04> Net - Connection port: 80
<18:14:04> Net - Connection default port: True
<18:14:04> Net - Connection proxy bypassed: True
<18:14:05> Net - Connection OK
<18:14:05> Net - Start listing available versions on [DL5]
<18:14:05> Net - 1.1.3.0 F 1
<18:14:05> Net - 1.1.7.7 B 1
<18:14:05> Net - 1.1.8.5 S 1
<18:14:05> Net - 1.1.9.5 S 1
<18:14:05> Net - 1.2.0.1 M 1
<18:14:05> Net - 1.2.0.2 L 1
<18:14:05> Net - 1.2.0.3 L 1
<18:14:05> Net - 1.2.0.4 L 1
<18:14:05> Net - 1.2.0.7 L 1
<18:14:05> Net - 1.2.1.5 S 1
<18:14:05> Net - 1.2.1.6 M 1
<18:14:05> Net - 1.2.2.0 L 1
<18:14:05> Net - 1.2.2.1 M 1
<18:14:05> Net - 1.2.2.9 S 1
<18:14:05> Net - 1.2.3.0 M 1
<18:14:05> Net - 1.2.3.1 L 1
<18:14:05> Net - 1.2.3.8 S 1
<18:14:05> Net - 1.2.3.9 M 1
<18:14:05> Net - 1.2.4.0 L 1
<18:14:05> Net - 1.2.4.1 M 1
<18:14:05> Net - 1.2.4.9 S 1
<18:14:05> Net - 1.2.5.0 M 1
<18:14:09> Cp - Retry thread started attempt #1
<18:14:09> Cp - Try to compare server with local file
<18:14:09> Cp - Connection port: 80
<18:14:09> Cp - Connection default port: True
<18:14:09> Cp - Connection proxy bypassed: True
<18:14:09> Cp - Connection OK
<18:14:09> Cp - 2016/12/2 上午 04:38:16 2018/11/18 下午 04:45:31
<18:14:09> Cp - Up-to-date
<18:14:09> Cp - Check Cp file
<18:14:09> Cp - Abort: Cp file to short
<18:32:42> Conf - Save conf file
<18:32:42> Conf - Save conf file [DONE]
<18:32:42> Exit(A)
Log started at 2018/11/18 18:33:09
Release ID: A65
Language: EN
Steam status: True
Master found: True
SKSE found: True
> Start logging:
<18:33:09> Conf - Initialize conf file
<18:33:09> Conf - Initialize conf file [DONE]
<18:33:09> Conf - Save conf file
<18:33:09> Conf - Save conf file [DONE]
<18:33:09> Conf - Initialize Version
<18:33:09> Conf - Checking Environment
<18:33:09> Conf - Checking Environment [DONE]
<18:33:09> Func - RWP: D:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<18:33:09> Func - RWP: D:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<18:33:09> Func - RWP: D:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<18:33:09> Func - RWP: D:\Program Files (x86)\Steam\steamapps\common\Skyrim\ top level
<18:33:09> Main - Initialize Unpatcher
<18:33:09> Unpa - Start cleanup
<18:33:09> Main - Unpatcher [DONE]
<18:33:09> Main - Create environment
<18:33:09> Main - Create environment [DONE]
<18:33:09> Main - Initialize network
<18:33:09> Net - Connection enabled in settings
<18:33:09> Net - System is connected to network
<18:33:09> Net - Try to establish server connection thread
<18:33:09> Net - Thread STARTED
<18:33:09> Main - Initialize network [DONE]
<18:33:09> Main - Initialize intervall
<18:33:09> Main - Initialize intervall [DONE]
<18:33:09> Main - Initialize PanBase
<18:33:09> Net - Choose server
<18:33:09> Net - Connect to [DL5]
<18:33:09> Net - Server connection attempt #1
<18:33:09> Main - Initialize PanBase [DONE]
<18:33:09> Main - Initialize CPanel
<18:33:09> Cp - Cp Initialisation
<18:33:09> Main - Initialize CPanel [DONE]
<18:33:09> Cp - No connection to server established yet, try again in 5 seconds...
<18:33:09> Cp - Check Cp file
<18:33:09> Cp - Abort: Cp file to short
<18:33:09> Conf - Hardware Scan:
<18:33:09> Conf - CPU: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz, Speed: 3301, Cores: 4
<18:33:09> Conf - GPU: NVIDIA GeForce GTX 970, Memory: 4 GB
<18:33:09> Conf - RAM: 8 GB
<18:33:09> Conf - DISC: 100699 MB
<18:33:09> Net - Connection port: 80
<18:33:09> Net - Connection default port: True
<18:33:09> Net - Connection proxy bypassed: True
<18:33:10> Net - Connection OK
<18:33:10> Net - Start listing available versions on [DL5]
<18:33:10> Net - 1.1.3.0 F 1
<18:33:10> Net - 1.1.7.7 B 1
<18:33:10> Net - 1.1.8.5 S 1
<18:33:10> Net - 1.1.9.5 S 1
<18:33:10> Net - 1.2.0.1 M 1
<18:33:10> Net - 1.2.0.2 L 1
<18:33:10> Net - 1.2.0.3 L 1
<18:33:10> Net - 1.2.0.4 L 1
<18:33:10> Net - 1.2.0.7 L 1
<18:33:10> Net - 1.2.1.5 S 1
<18:33:10> Net - 1.2.1.6 M 1
<18:33:10> Net - 1.2.2.0 L 1
<18:33:10> Net - 1.2.2.1 M 1
<18:33:10> Net - 1.2.2.9 S 1
<18:33:10> Net - 1.2.3.0 M 1
<18:33:10> Net - 1.2.3.1 L 1
<18:33:10> Net - 1.2.3.8 S 1
<18:33:10> Net - 1.2.3.9 M 1
<18:33:10> Net - 1.2.4.0 L 1
<18:33:10> Net - 1.2.4.1 M 1
<18:33:10> Net - 1.2.4.9 S 1
<18:33:10> Net - 1.2.5.0 M 1
<18:33:14> Cp - Retry thread started attempt #1
<18:33:14> Cp - Try to compare server with local file
<18:33:14> Cp - Connection port: 80
<18:33:14> Cp - Connection default port: True
<18:33:14> Cp - Connection proxy bypassed: True
<18:33:14> Cp - Connection OK
<18:33:14> Cp - 2016/12/2 上午 04:38:16 2018/11/18 下午 04:45:31
<18:33:14> Cp - Up-to-date
<18:33:14> Cp - Check Cp file
<18:33:14> Cp - Abort: Cp file to short
<18:39:28> Conf - Save conf file
<18:39:28> Conf - Save conf file [DONE]
<18:39:28> Exit(A)
Release ID: A65
Language: EN
Steam status: True
Master found: True
SKSE found: True
> Start logging:
<18:32:42> Exit(A)
Release ID: A65
Language: EN
Steam status: True
Master found: True
SKSE found: True
> Start logging:
<18:39:28> Exit(A)
I think I found the reason, I use English Launcher it work!
But the problem still exists,the Launcher-CN Still not working!!
The links on Enderal.com are probably outdated due to a lack of up-to-date information by the Chinese translators.
Here is the Chinese page with all information and installation instructions.
If this contains the latest chinese patches, I couldn't find out on the quick one.
http://9dm.zhongyidiantong.com/thread-2581-1-1.html
Registration on the site is required for downloads.
EDIT:
I've just learned that the Chinese language patch will be retrieved in the Launcher-CN with the updates.
So if you don't use the English Launcher but the Chinese Launcher for installation and updates, there shouldn't be any problems.
EDIT:
Thank you for your help
