when I start the game through the launcher the main menu does not appear and is just a blue screen. the normal options are still there like new game, credits, etc but when I click new game it crashes with the message that "Skyrim has crashed because an object reference with form ID: 0x125531, base form ID: 0x67137 and type:0x22 failed to produce loaded node most likely due to corrupted mesh or other reason"
(p.s) I am using mod organizer and have no other mods enabled other than enderal
welcome to the forum
delete the two *.ini files and restart the game (it will create a new one on launch);
they are usually located in ...\Documents\My Games\Skyrim,
but MO creates it's own (if I'm not mistaken?), so you need to find these (no idea where, sorry),
and delete them (same as above though, new ones should be created one launch)
if that doesn't already work, upload the launcher.log please, stored in ...\Skyrim\Enderallauncher\system\log
hope that helps
hope that helps
EDIT (in new post for better visibilty)
paraphrasing user Stefanie:
the MO ini should be in "%USERPROFILE%\AppData\Local\ModOrganizer\Skyrim\profiles\Default",
depending on your configuration and profile name![]()
I have deleted the ini files for both skyrim and MO although that does not seem to be working here is my log
Launcher.log
(4.83 KiB) Downloaded 594 times
hm.
safest, but most time consuming option
what you can try first
- open the file config.sur in
...Steam\steamappsommon\Skyrim\EnderalLauncher\systemonfig
- edit the line sCurrentVersion=x.x.x.x to sCurrentVersion=1.0.0.0
- run the Launcher as admin and reload the patches
ok thanks, ill try that and let you know if that works
Same problem.
Thats because Windows 10 patch KB4462917.
It was released on 10.10 and have conflicts with skse i think, no chance to run it with this update... So i uninstalled it and everything wokrs fine... But after pc restart this pc update coming and updating again
Dont think this will resolved soon, because mainly its not Endoral problem, its software Win <-> Skse prob...
Ok. DO NOT DELETE this shit update.
On 3d time it ruined my system. Writing from phone
uhm
that would be bad
how do you know it's skse?
can you launch Enderal (and Skyrim) without it?
__________________
oh wow, sorry to hear that
that would be bad
__________________
Ok. fixed windows
Problem was with Skyrim with skse and Enderal (with skse, dunno how to run it without, now cant test, pc is clean as virgin, only downloading skyrim now...).
Without skse Skyrim stared ok, and after i removed update (and reboot ofc) Eneral started work fine. So i think its skse-win problem, dont know, will test later, after everythink will dl and install
