6 posts • Page 1 of 1
New game problem
Post by Kecskehippi »
Hi guys! I will be short.
I just downloaded Enderal (via Torrent) and installed it up with a vanilla Skyrim. Everything was fine for about two minutes, because then i tried to start a new game.
After the loading screen the game didn't start, only gave me an Error Message.
Skyrim has crashed because an object reference with form ID: 0x14C272, base form ID: 0x9A787 and type: 0x22 failed to produce loaded node most likely due to corrupted mesh or other reasons.
(P.S.: I tried to delete Skyrim.ini and SkyrimPrefs.ini from .../documents/My Games/Skyrim, and it doesn't worked.)
Re: New game problem
Post by Stefanie »
Have you installed any mods? (If yes, please uninstall them and try again)
Did you do all the updates for Enderal?
Please also upload your Launcher.log here.
You can find them at: ...\Steam\SteamApps\common\Skyrim\EnderalLauncher\system\log
Do you use ModOrganizer?
Then the .ini might be saved in your MO profile and deleting the Skyrim-ini under MyGames\Skyrim won't help.
In this case we would need the .ini from your MO-Pofil.
I didn't installed any mods, but updated Enderal and of course I never used ModOrganizer.
Post by urst »
the launcher.log ( ...\Steam\SteamApps\common\Skyrim\EnderalLauncher\system\log) would still be nice ;)
You can donwload it from this link: https://files.fm/u/e6g29am9
Launcher.log
(292.69 KiB) Downloaded 97 times
Post by urst »
hm, I guess it's pure coincidence that there's a repack named "kaos" floating around,
just like the one in your file path.
just in case that it's not
you might want to think about buying the game, that should help with the error,
your conscience and your chances of getting any sort of support :dumb:
(since we really don't support that kind of stuff)
