7 posts • Page 1 of 1
Ritual effect stuck on me
Post by ffak »
hello
I read this topic https://forum.sureai.net/viewtopic.php? ... 947#p82053 because I've got exactly the same mist stuck on me.
The fix do not work.
What can I do? This fog/mist is very annoying.... :dead:
thanks for helping.
and the effect is indeed caused by this ritual (and not, say, from some wisps or something)?
  • Save your game.
  • Walk to any NPC.
  • Open up the console and click on the NPC (hexadecimal number should be displayed)
  • type in the following:
    cast a7f8d player left
  • press enter and close the console
  • a weird animation starts
You should be good.
Maybe you have to try two or more times to make it work.
did not work?
can you load an earlier save?
that would really be the easiest solution.
could you upload a savegame?
found in ...\Documents\My Games\Skyrim\Saves,
we'll need the skse and the ess of a manual (no quick- or auto-) save,
pack them to a rar or zip archive and attach them to a post here :)
Do you have any mods installed?
If yes, which?
Disable or uninstall it and test it again.
If that and also the instructions from Stuemper do not work, upload a Savegame here.
Can be found at: "% USERPROFILE% \ Documents \ My Games \ Skyrim \ Save".
(Please no Autosave or Quicksave, but manually saved)
Good would be a Savegame just before and after the problem.
So we can try to find a solution.
disable the 7 mods I have.
Same result.
I'm unable to load pre-ritual savegame, I always overwrite previous saves.... :? :sick:
Here is mys save game
Saves.zip
(2.06 MiB) Downloaded 211 times
not trying to argue, but are you sure it's that effect :?:
the "fog" surrounding you is a different colour (on the other hand, that could also be the lighting),
and you're a good deal farther in the mainquest.
is that effect following you for days?
there's a thread in the Nexus-forums which might be helpful (sadly it wasn't yet with Enderal effects)
That you do not have an older Savegame is a great pity. In the future:
Save a lot and do it manually too.
You have a disease and an inexplicable bonus to elementalism among active spells.
Of your 7 mods, I do not see a direct connection, but it is still possible that they damage your savegame.
Whether this is still to be saved, I can not tell you on the fast.
I will try the console solution later.
But I hope, that someone is watching, who has more experience.
The effect that was applied to your character has nothing to do with the effect that gets applied during the mainquest.
To be honest, I have no clue what effect this is.
Mya suggestion would be to load an earlier save game and replay. If the effect gets stuck on you character again, make sure you catch the moment, so you can tell us on which occasion it happens.
