So I recently uninstalled Enderal to play my old non-Enderal saves.
Only problem is that every single save created before installing Enderal crashes to desktop when saving, fast traveling or changing cells.
I havent changed anything else besides installing Enderal.
New characters seem to work just fine.
Hope you can help me on this one.
Enderal doesn't alter anything regarding your saves / savegame directory. My best bet would be to remove your Skyrim.ini and SkyrimPrefs.ini in C:\User\Documents\my games\Skyrim\
Both files will be automatically regenerated when you start Skyrim.
i had the same issue for the longest time then i found out uninstalling enderal and then uninstalling/reinstalling skyrim as well as disabling any possible mods (if any were in use) for enderal via mod manager and its worked fine since.......... mind you i still crash occasionally but thats only due to me playing skyrim/enderal on a potato
