16 posts • Page 1 of 1
expanded+ orn 2.0 orn face changes because of it. sorry I don't speak fluent Engli. help!! plz!!
https://forum.sureai.net/viewtopic.php? ... 840#p98840
welcome to the forum :)
I really never used Nehrim Expanded, that's why I didn't answer you.
so you first installed ORN (and that worked on it's own),
then you tried installing Nehrim Expanded and it stopped working.
am I understanding that right?
are you running Nehrim with the obse_loader?
No!
I did it with the nehrim loader and made it according to the installation recipe
that might be the problem - ORN needs obse, as far as I know. (and I think NE needs it too?)
do you have it installed?
but it's possible that the launcher already uses obse -
could you check that?
in the Nehrim Launcher under
Einstellungen -> Extras
"OBSE bei Spielstart mitladen"
and you seem to have the Oblivion.esm in your data folder?
I don't :/
maybe there's something else wrong with your main installation :?:
are there any other issues, beside that mod not working correctly?
Checked. It seems to be another problem.
nehrim expanded + orn 2.0 The file that was confirmed to run well Can you give me the installed files?
that's what my Data folder looks like
(the grey marked stuff is just other mods)
user Stefanie told me, she does have the Oblivion.esm in that folder, she just deletes it after installation :/
sooooo.
really not sure.
Oblivion.esm delete.
It seems that it is a faster solution to send your files to me
Sorry but it is too important for me
this mod my life i need orn+ nehrim expaneded please...
as I said, I never used Nehrim Expanded :(
only things I could suggest right now would be to load NE after ORN, or, if that doesn't help,
do a clean reinstall (with first installing Nehrim, then NE, then ORN)
I have never tried it as you said
Will you install it in your file and see if the same phenomenon happens like me?
okay.
I tried installing it (everything, the whole package), and it worked fine.
do you have wryeBash installed?
it might need the bashed patch :?:
no
wryebash How to use it
If the operation goes well it will be resolvable if it is your nehrim file
Can you send me a nehrim file of yours? After that, I'm sure I can solve it
I'm not sure how a Nehrim file would help with that :/
and there are instructions included in the NE manual
I'll try it in english
the installation file is included in the NE package
(...\Nehrim Expanded Komplett\Manuell\01 Wrye Bash)
run it as admin
there is nothing to change in the following window.
next one is this
remove the check mark from "install for Oblivion",
set one to "install to extra locations"/Extra location #1"
and enter the path to Nehrim
stays like that
you are asked about starting the tool.
(and you should now have a "Mopy" folder within the Nehrim folder)
opening wrybash.exe you see something like that
(just with other mods)
right-click on Bashed Patch_0.esp and rebuild patch.
(with ORN and NE enabled)
then start the game
that should help
What to check
hmmm, according to the manual you need to move NE above ORN,
and then just "merge Patches" :)
I love you!!!!!!!!!! Thank you !! Your mod my life i love nehrim i love enderal !
so it works now?
that's awesome :thumbsup:
have fun :D
