4 posts • Page 1 of 1
I set up the distant setting at 'SkyrimLauncher.exe' to max. However, tree or object in distance is steel invisible and water is unloaded, terrain is purple, all the landscape is purple in distance. pls take a look at above link.
I tried to reinstall Enderal, but nothing changed.
How can i fix it?
How can i fix it?
welcome to the forum :)
my first guess would be to delete the two *.ini from ...\Documents\My Games\Skyrim and restart the game.
(it will create a new one on launch)
that may already do it. (yes, on new install too ;) )
it also might help to
[+] reset the patches
- open the file config.sur in
...Steam\steamapps\common\Skyrim\EnderalLauncher\system\config (with Notepad)
- edit the line sCurrentVersion=x.x.x.x to sCurrentVersion=1.0.0.0 and save
- run the Launcher as admin and reload the patches
otherwise your main download may be corrupted :?:
did you use the torrent? it's usually the safest to prevent that.
you may have to redownload the installation file :(
How can i fix it?
Thank you for the quick Answer. Honestly, I didn’t think it’s this quick that someone answers my question.
And, finally, I could fix it. Guess i just have downloaded wrong version.
Thank you.
good to hear it works now :)
have fun :thumbsup:
