5 posts • Page 1 of 1
Hello new to forum
Post by Kampfar86 »
No idea where to find English part of the forum since whenever i go skyrim 5 i am automatically in the German section.
Not even sure if this is the right section to ask but here it goes.
When i install Skyrim 5 (Special edition) and add the Enderal launcher into the game folder, whenever i start the launcher i get this message. https://pasteboard.co/H5QuHH6.jpg
What is skyrim classic and where to get skyrim classic (There is Skyrim Limited edition, legendary edition etc.) cuz once i installed the razor 1911 version of skyrim, added the Enderal launcher, did all the updates and wanted to start the game i got the message that skyrim 5 is not up to date...
Re: Hello new to forum
Post by urst »
welcome to the forum :)
1)I moved you to the english forum :)
2) Enderal doesn't work with the Special Edition - you'll need the 2011 version; Skyrim Classic
3) "razor 1911 version of skyrim"... is that a cracked version?
absolutely not supported.
[+] 4
(here you go, kermit.
hope you're happy)
Post by Stefanie »
Your tread has been moved to the right section.
The english part is directly under the german part in the forum overview
here: https://forum.sureai.net/index.php
The direct link to the English part is: https://forum.sureai.net/viewforum.php?f=157
There you would be correct in support.
Enderal was made for Skyrim (originally or also called Classik).
"Skyrim Limited edition, legendary edition" is the full version, with the official extensions.
She is also suitable, but not necessary.
The newer 64bit version called "SkyrimSE" or "Secondary Edition" is not suitable for this.
Therefore, the launcher will not find the right file for your game.
Hopefully when you talk about Razor 1911, you're not talking about a Steam-free version, or any other Crack version.
Because that will not work with Enderal and not supported by us.
You will need the original version and this in turn needs Steam.
So the only life we've seen in this English forum for the past few weeks is someone coming here using a pirated version of Skyrim. :roll:
Thank you!
SureAI does not support illegal copies.
You already have to buy a legal Steam version of Skyrim 32 Bit. They are already very cheap (for example, with key sellers).
