Hello,
Just yesterday i installed Enderal and i solved error (u see photo) by deleting Skyrim.ini and lauching game again. Now i get that the program has stopped working after i press "Continue" in the game background.
Some info about pc:
AMD FX(tm)-6100 Six-Core Processor, 8 RAM, 64-bit Operating System, x64-based processor, Windows 10
I really hope that u can help me
Some info about pc:
Welcome to the forum!
Close Enderal and the Enderal Launcher and delete/remove the Skyrim.ini AND Skyrimprefs.ini (both files!) from ...\Documents\My Games\Skyrim.
At the next startup of the game they will be automatically rebuilt. If that does not work, attach the Launcher.log from ...\program files (x86)\steam\steamapps\common\Skyrim\EnderalLauncher\system\log
Well, first solution didn't helped.
I don't have steam - is it necessary? So i don't find steamapps folder.
Maybe i just can download that file from somewhere?
You must have the file launcher.log in your installation directory. Similar as above. Search it...
Hmm, so i added Launcher.log to My documnets/my games/skyrim, but error still exists, but i figured out how to launch a game withouth it. When i am preessing continue the error exists, but when i press New Game, then going to Main menu again and pressing Continue or Load game the error is gone. Maybe now we can solve it?
Or else i will have to launch the game like this
We have to take a look at your launcher.log.
Please attach it to your message here.
There's a button under the message.
-could you check the size of your installation package?
it should be something around 7,84 GB (8.427.966.464 Bytes) for the English version
-could you post a screenshot of your Data folder?
(where the bsa and esm files are - skyrim.esm, een-scripts.bsa and so on)
(just asking stuff; can't actually help, sorry
The instalation package i got is 8 427 964 531 bytes
Yeah, sure
Yeah, sure
Enderal wasn't installed properly on your PC, you have multiple outdated files and folders in your directory. I would recommend to reinstall it from a newly downloaded installation package. Make sure to run the Enderal Launcher as admin.
If you have Steam, I would recommend to install Skyrim via Steam to avoid any problems.
I reinstalled 2 times yesterday.. And i don't have steam..
did you reinstall Skyrim as well?
also, "from a newly downloaded installation package"?
yours likely got corrupted; use the torrent option to be safe
You probably have Skyrim 1.00?
But you need the latest version of Skyrim 1.9.32, so you need an update via Steam. (also on the Skyrim DVD or online)
To do this, you must install Steam, create an account, register, and update Skyrim.
The Skyrim key should be on your Skyrim DVD.
Only then can you install Enderal (and then update)
And then you can play Enderal.
Of course your Skyrim should be legal.
