34 posts • Page 1 of 2
how do i fix that?, it's keep pop up when i tried update
i reinstall skyrim and enderal, and sometime the update work, and i can play the mod
but when i restart my computer and tried to play again, it's got problem in skse said "please update latest skyrim update"
and it's keep on and on, i really want to play this mod but it's keep got problem in my PC :(
Could you show us, what it displayed under the button "details"? Also a launcher.log from C:\Program files (x86)\steam\steamapps\common\Skyrim\EnderalLauncher\system\log\ could be helpful to solve this issue.
the detail button reveal
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt64(String value, NumberStyles options, NumberFormatInfo numfmt)
at System.Convert.ToInt64(String value)
at Launcher_01.formPanUpdate.checkDownloadOrExtractFile()
at Launcher_01.formPanUpdate.btnDownloadUpdate_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2600.0 built by: NET471REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Enderal Launcher
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///d:/steam/steamapps/common/skyrim/enderal%20launcher.exe%C2%A0
Win32 Version: 4.7.2556.0 built by: NET471REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Management
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
btw i attach the launcher log too
thanks for reply, i hope that can help fix the problem
it's persist from the first time i want to tried this mod
2 years ago ? =w=
Launcher.log
(16.18 KiB) Downloaded 298 times
Re: Update and SKSE error
Post by Hoxyd »
To give you a first insight what causes this problem: The Launcher can not find your hard drive to work on, and don't know how much space there is to work with.
<17:05:26> Conf - DISC: No hard disc found.
Is there some special configuration on you computer / hard drive? And how much free space is there in fact?
there's no special configuration..
but i will check it in bios later
and i still have a lots of free space, like 200 gb
the problem is, it's didnt effect even i change os from windows 7 to windows 10
and the funny thing is, if even i can get it's updated, i will get problem in skse later
Post by Hoxyd »
I changed the hard drive part in the Launcher. You can try it with the attached one.
Enderal Launcher.zip
(2.53 MiB) Downloaded 237 times
oh my god, it's work now
thank you very much
can i know what happen? it's problem in my PC or there's some bug in launcher?
i hope the skse is work too later
Post by Hoxyd »
Ok, be sure to download the file again after the update, if there is a problem. The update archive contains the old launcher and so this can cause the same problem after the update installation.
sorry for a long reply, the update is kinda slow >__<
ok now the skse problem =w=
Post by Hoxyd »
I do not know anything about SKSE, but can you start the skse_loader without the launcher? If it works, start the game that way.
it's same...
that's why i kinda frustated
if i got the update work, i got stuck in SKSE
Did you install SKSE separately (as we know it from Skyrim)?
That would be a mistake.
Then you would not have the skse version already included in Enderal.
no i dont install skse separately
i know what to do, because i already install all SureAi mode from Artkwend to Nehrim
and it's the only mod from SureAi that give me hellish problem :dead:
i install Skyrim clean without any mode, then i install enderal directly because i know i will get skse from enderal, the funny thing is, sometime the skse work, but after i restart PC, it's got the same problem again
Post by urst »
if that only (mostly?) happens after a reboot, you could take a look into Windows' event log
(I can only give you german translations - actual words can be different):
(right after the next crash)
- search via taskbar for "event viewer"
- in that screen, open "custom views" and then something like "administrative events"
- is there anything of particular interest in that list on the right?
something like skse / Enderal launcher /... stopped working?
(there are probably a lot of errors; most of them can be safely ignored)
did you try to redownload the mainfile?
maybe it's corrupted for some reason :?:
torrent would be the safest.
Post by Hoxyd »
I am not familiar with how SKSE works. Might be the same problem like with the Launcher. SKSE can not detect our hard drive and so can not find your SKSE installation dlls, maybe.
What happens if you open your Enderal installation package and copy the SKSE files in your game directory. Does it run?
@urst
i already check via administrative event and there's nothing like you mention above
and yeah i already redownload many times fresh from enderal and it's torrent one
@hoxyd
i already tried like what you said, extract the skse from enderal package too
but it's doesnt work and always said "latest skyrim update" like screenshoot i give above
Post by Hoxyd »
Unfortunately nothing we can do here, since we have no control over how Skyrim Skript Extender works. You can only try to re download it form: http://skse.silverlock.org/ and check if it does something (not sure if it breaks the game, but it does not run anyway, so why not just try).
Post by urst »
have you tried running Skyrim with skse?
wait actually the Enderal is work
VIA SKYRIM LAUNCHER @_@
if i play via Enderal Launcher it will get message latest update skyrim obviously
but if i play it via Skyrim launcher, i can play the Enderal because of course Enderal installation overwrite launch and data priority in skyrim
but i got this message
i will give update if there's any error again..
Without SKSE, Enderal will not work properly, not just SkyUI, other errors are likely.
It's an attempt to manually install SKSE and then use skse_loader.exe.
Only test option.
Starting the game via Skyrim Launcher or directly TESV.exe does not solve your problem properly.
If Steam is running in the background and Skyrim is installed correctly,
SKSE should also recognize your game version correctly.
Where is Skyrim / Steam installed?
On a normal HDD, e.g. C: \ ...?
I would suspect rights management of windows?
