Hello! I just installed the game, and i think that i did everything right but when i open a new save it looks like this and i don't know how to fix it! Someone please help me as fast as possible, thanks! link to screenshot: https://imgur.com/a/4bytq
You probably have an ENB installed which is not compatible with Enderal. I would recommend to remove all files related to the ENB from your installation directory.
However if you have a compatible ENB installed, you should disable Anti-Aliasing.
19.11.2017 13:26SosseJosse wrote: Hello! I just installed the game, and i think that i did everything right but when i open a new save it looks like this and i don't know how to fix it! Someone please help me as fast as possible, thanks! link to screenshot: https://imgur.com/a/4bytq
Enderal map bug
20.11.2017 16:30Matteum Primo wrote: I've the same problem, although I've disable anti aliasing and FXAA in game. Could it be a GPU incompatibility? I've got a NVIDIA GTX 970. Thanks in advance for your attention.![]()
Your issue is related to the World Map. Check out this post.
20.11.2017 16:41stuemper wrote:That's not the same problem at all. The initial post is about an ENB issue.20.11.2017 16:30Matteum Primo wrote: I've the same problem, although I've disable anti aliasing and FXAA in game. Could it be a GPU incompatibility? I've got a NVIDIA GTX 970. Thanks in advance for your attention.![]()
problem solved.
