4 posts • Page 1 of 1
I can't install Enderal
Post by Poxopi »
I tried to install it, but I get the following error :dead: :
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.UnauthorizedAccessException: Access to the path 'C:\Program Files (x86)\Steam\steamapps\common\Skyrim\data\meshes\actors\character\_1stperson' is denied.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileSystemEnumerableIterator`1.AddSearchableDirsToStack(SearchData localSearchData)
at System.IO.FileSystemEnumerableIterator`1.MoveNext()
at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
at System.IO.Directory.GetFiles(String path, String searchPattern, SearchOption searchOption)
at Launcher_01.formPanSetUp.collectFilesSkyrimDirectory(String backupPath, gameBackup game)
at Launcher_01.formPanSetUp.Installswitcher(SByte i)
at Launcher_01.formPanSetUp.btn_InstallationNext_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2115.0 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Enderal Launcher
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Steam/steamapps/common/Skyrim/Enderal%20Launcher.exe
Win32 Version: 4.7.2110.0 built by: NET47REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.7.2046.0 built by: NET47REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.7.2116.0 built by: NET47REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Win32 Version: 4.7.2102.0 built by: NET47REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Management
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Ionic.Zip
Assembly Version: 1.9.1.8
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
someone please help!
welcome to the forum :)
- did you run the launcher as administrator (right-click -> run as admin)?
- can you check for a reading/writing protection on the file?
( 'C:\Program Files (x86)\Steam\steamapps\common\Skyrim\data\meshes\actors\character\_1stperson')
Forgot about this bugly launcher!
Do next:
prepare Skyrim DVD
EnderalInstall_RU.gz (download from torrent: magnet:?xt=urn:btih:CPNBQGZXJBAIOG3D3FT4EEMPHDEVSXS4
go to http://1.dl2sureai.de/files/pro/enderal/upd/getlist.php?laun=&lang=en
->you got the text file like as:
EnderalUpdate_[1.2.2.1][M][1]_EN.zip EnderalUpdate_[1.2.2.9][S][1]_EN.zip EnderalUpdate_[1.2.3.0][M][1]_EN.zip EnderalUpdate_[1.2.3.1][L][1]_EN.zip
and download all it? making links like
http://1.dl2sureai.de/files/pro/enderal/upd/en/EnderalUpdate_[1.2.2.9][S][1]_EN.zip
http://1.dl2sureai.de/files/pro/enderal/upd/en/EnderalUpdate_[1.2.3.0][M][1]_EN.zip
http://1.dl2sureai.de/files/pro/enderal/upd/en/EnderalUpdate_[1.2.3.1][L][1]_EN.zip
and all after.
Install Skyrim
remove from it:
plugins.txt
Skyrim.ini
SkyrimPrefs.ini
DATA\Dawnguard.bsa
DATA\Dawnguard.esm
DATA\Dragonborn.bsa
DATA\Dragonborn.esm
DATA\HearthFires.bsa
DATA\HearthFires.esm
DATA\Skyrim.esm
DATA\Skyrim - VoicesExtra.bsa
DATA\Update.esm
DATA\Video\* <- т. е. "*" means all entire of this folder
DATA\Textures\*
DATA\Strings\*
DATA\Scripts\*
DATA\Sound\*
DATA\Interface\credits.txt
DATA\Interface\fontconfig.txt
DATA\Interface\fonts_console.swf
DATA\Interface\fonts_ru.swf
DATA\Interface\hudmenu.swf
DATA\Interface\levelupmenu.swf
DATA\Interface\rus_fix.swf
DATA\Interface\Translate_RUSSIAN.txt
unpack EnderalInstall_RU.gz
unpack EnderalUpdate_[1.2.1.0][S][1]_RU.zip, after EnderalUpdate_[1.2.2.0][M][1]_RU.zip, and all other newer updates
confirming replacement of files.
start SkyrimLauncher to preconfig the game
All OK. Let's play.
!don't forget that Enderal and Skyrim places they saves and settings to the same directory %userprofile%\Мои документы\My Games\Skyrim
[hr]
there is original russian instruction:
1) Загрузка необходимых файлов:
Собственно логичный указанный torrent
его магнит:
да, там внутри одни почти 8гиговый EnderalInstall_RU.gz. Придётся поизвращаться. Более человеческих вариантов мне пока не попадалось.
Но это ещё не всё!!! ибо в этом архиве отсутствуют необходимые файлы данных!
Идём туда: http://1.dl2sureai.de/files/pro/enderal/upd/getlist.php?laun=&lang=ru
в ответ будет текстовый файл, что-то вида:
EnderalUpdate_[1.2.0.8][M][1]_RU.zip EnderalUpdate_[1.2.0.9][M][1]_RU.zip EnderalUpdate_[1.2.1.0][S][1]_RU.zip EnderalUpdate_[1.2.2.0][M][1]_RU.zip
соответственно - список имён файлов через пробел.
Формируем конечные ссылки, подклеивая к ним начало: http://1.dl2sureai.de/files/pro/enderal/upd/ru/
т. е. итого например: http://1.dl2sureai.de/files/pro/enderal/upd/ru/EnderalUpdate_[1.2.1.0][S][1]_RU.zip
однако качать всё не обязательно: Движемся от конца строки к началу ища [S],
и соответственно качаем самые крайние [S] и [M] файлы. [S] это ключевое дополняющее обновление, [M] - базовое.
Вот теперь у нас есть полный комплект файлов Эндерала!
Ну и в дополнение нам нужен ЧИСТЫЙ! Скайрим, нормальный, не LE!!! и обновления к нему (по надобности).
Ну, тут понятно откуда. Например с диска с этой игрой из магазина.
2)Можно начинать собственно установку.
Устанавливаем Скайрим, и все обновления к нему (если твой дистрибутив не с последней версией игры)
Выкидываем из папки с игрой следующее:
plugins.txt
Skyrim.ini
SkyrimPrefs.ini
из папки DATA
DATA\Dawnguard.bsa
DATA\Dawnguard.esm
DATA\Dragonborn.bsa
DATA\Dragonborn.esm
DATA\Skyrim.esm
DATA\Update.esm
DATA\Video\* <- т. е. "*" тут подразумевает всю эту папку.
DATA\Textures\*
DATA\Strings\*
DATA\Scripts\*
DATA\Sound\*
(впрочем ничего страшного если на это забить, но обязательно надо выкинуть все esm и esp файлы!)
Далее распаковываем EnderalInstall_RU.gz в папку с игрой.
Далее распаковываем туда-же скачанные zip файлы "обновлений" (на момент написания инструкции это
EnderalUpdate_[1.2.1.0][S][1]_RU.zip и EnderalUpdate_[1.2.2.0][M][1]_RU.zip). Заметка! распаковывать
следует начиная от младших версий к старшим, соглашаясь на замену файлов.
Проверяем в менеджере модов что все появившиеся esm, esp файлы включились в список загрузки (скорей всего будут по умолчанию).
В принципе это можно сделать и через оригинальный skyrimlauncher.exe, а заодно им-же и произвести предварительную
настройку графики и звука игры.
Можно играть (запускать через skse_loader.exe)
(кстати не забываем, что Enderal свои сохранения складирует туда-же куда и Skyrim, т. е. в %userprofile%\Мои документы\My Games\Skyrim,
соответственно дабы новые сохранения и настройки не налазили на возможно уже имеющийся у тебя Skyrim следует
переименовать\переместить\... выше указанную папку! Ну и соответственно переключение между двумя этими играми производится подстановкой
"нужного" содержимого. В довершение скажу - ничего страшного если ты запустишь "не ту" игру не подставив нужной папки сохранений -
- сохранения от этого не испортятся (ну а загрузить сейв не от той игры у тебя скорей всего не выйдет, но в любом случае это будет заметно)
В дополнение, дабы кому расшевелить ихний лаунчер:
1)Убедиться что твоя ОС - Windows7 и новее, что у тебя стоит .Net 4.5 или новее
и установлен комплект MSVCRов начиная с 2005го по 2017й.
2)собственно закинуть его в папку с игрой
3)создать файл EnderalLauncher\system\config\conf.sur
с текстом:
[Values]
bBackupStatSkyrim=0
sBackupPathSkyrim
bBackupStatEnderal=0
sBackupPathEnderal=path
sCurrentVersion=1.2.0.0
bInstallUpdateAfterDownload=0
sSkyrimFolderPath=.
bNetConection=1
bStartSteamOnLauncherStart=0
bCloseLauncherAfterGameStart=1
bUseOneTweak=0
bInstallStat=1
Всё. Теперь ихний лаунчер будет считать что игра установлена. Правда зачем он нужен???[/code]
It looks like you were able to install it, did removing the write protection solved the Launcher problem?
Anyway, I just looked into the launcher files and changed the write protection method to make it more strict. It will be delivered with patch 1.2.4.0. Thanks for the report.
