its stuck and wont play any idea why?
my load order is below
GameMode=Skyrim
Skyrim.esm=1
Update.esm=1
Equipping Overhaul.esp=1
dD - Realistic Ragdoll Force - Realistic.esp=1
Rough Leather Armor.esp=1
Skyrim Realistic Archery.esp=1
HunterArcherCuirass.esp=1
Action Combat.esp=1
DeadlyCombat.esp=1
TKDodge.esp=1
WetandCold.esp=1
FNIS.esp=1
BosmerArmorMATY743.esp=1
GameMode=Skyrim
Skyrim.esm=1
Update.esm=1
Action Combat.esp=1
DeadlyCombat.esp=1
TKDodge.esp=1
WetandCold.esp=1
FNIS.esp=1
welcome to the forum
first step would be to try without mods.
best (at least for us) would be if you'd deactivate one at a time,
so we know which one's the problem.
(dD - Realistic Ragdoll Force - Realistic, Action Combat, DeadlyCombat, Equipping Overhaul and TKDodge look like likely culprits)
if that doesn't work you could upload your savegame.
found in ...\Documents\My Games\Skyrim\Saves,
we'll need the skse and the ess of a manual (no quick- or auto-) save,
pack them to a rar or zip archive and attach them to a post here
03.11.2017 15:44urst wrote: welcome to the forum
pack them to a rar or zip archive and attach them to a post here![]()
Saves.zip
(1.1 MiB) Downloaded 396 times
thanks
your savegame works fine on my game (without mods)
did you try without them?
if you did, and it doesn't work for you, while we have no problem, there's obviously another issue :/
03.11.2017 17:30urst wrote: thanks
03.11.2017 18:11bgbg wrote:I actually had to reinstall enderal because I verifyed my game cache lol,03.11.2017 17:30urst wrote: thanks
but I did try it with no mods and it works so should I just keep activating mods 1 by 1 and see what messes it up?
And is that what you guys do when you pinpoint a problem or do you actualy look into the save itself?
- I'm not in any way involved in the game's developement by the way
(meaning "I don't know s**t"); I can only speak from experience
- yes, I'd slowly reactivate them. armors should be fine, the other stuff... maybe not so much
(you'd need to test them on that scene though - if the game worked fine til now,
it will most likely keep working til the next scene
- if an issue is solved by simply deactivating the offending mod,
no other measures are taken
--- we launch the game without mods and load the provided save;
if it works then mods are the most likely reason
- if there is some other problem, unrelated to mods, then yes, someone who actually knows stuff will look at
the save itself.
hope that answers your question
