8 posts • Page 1 of 1
It happens alot during loading.
some time this message shows:-
The mods i'm using:-
Save file:-
https://drive.google.com/open?id=0B73X3 ... GNmdGt3cFU
https://drive.google.com/open?id=0B73X3 ... 0pIYkE1cW8
I don't Know if the problem from me or the game, Please inform.
Cheers.
Welcome to the Forum!
We also need the ess file of your savegame (not only the skse) :wink:
Does the game crash at the start?
I guess this is problem with one or some of your mods.
I do not know all but Enhanced blood is no longer compatible with Enderal and can cause serious problems.
Disable all your mods. You can then test them individually.
welcome to the forum :)
- we'll need the ess of the savegame as well
you can upload both packed to a rar or zip file or something and attach it to a post here. :)
- Campfire and Wet And Cold are pretty scriptheavy, aren't they? bit risky in Enderal.
might be the issue; not sure if we're even able to load your save without those two mods present :(
otherwise the error looks like a broken ini :/
you could delete the skyrim.ini from ...\Documents\My Games\Skyrim?,
but if that would be the issue you'd probably see that ingame
done.
No the game does not crash at start.
I well check the mods one by one and report later.
Good idea! Because this helps all users here!
I could load your savegame and played with it for about... twenty? twentyfive? minutes.
without crash.
made a point of loading as many different cells as possible.
would you say that that's longer than usual?
in that case it's most likely really one of the mods.
I tested the game after disabling all the mods, the problem exists.
how long are you able to play?
does it crash only during loading?
if it crashes after exactly 15 minutes, no matter where, look at this
- open the taskmanager
- in the tab "services" look for something called "TabletInputService" or "tabtip"
- disable it
the service belongs to a graphics tablet? or a touchscreen?
something like that
____________
but that's unlikely.
did you delete the ini to see if that changes anything?
the game creates a new one on launch
you could also take a look at ENBoost,
which in general reduces crashes, but this case seems something else
