2 posts • Page 1 of 1
Kind of gamebreaking: trying to do one of the black stone quests and can't get past Adila. The interaction between her and Jespar will play just fine, but if I try to confront her the game freezes; also will freeze if I try to open console or any menu. As the title says, I'm using Skyrim Special Edition, which has run mostly fine until now. Attaching mod list just in case, but I've tried deactivating them all and it has made no difference. I've also tried removing gold, since that has caused problems and crashes before.
Welcome to the forum :)
Enderal is simply not compatible with the Special Edition.
it needs SKSE, which doesn't exist (yet).
I consider it a miracle that you even came that far :shock:
of course, you could upload a savegame, maybe we can take a look at it anyway,
but don't get you hopes up :(
they're found in ..\Documents\My Games\Skyrim\Saves,
we'd need the skse (which you probably don't have?) and the ess of a manual (no quick- or auto-) save,
pack them to a rar or zip archive and attach them to a post here.
(ess only should be uploadable on it's own. the forum just doens't like skse)
